Hello,
I have a 2000 Silverado 2500 with the LQ4. I have attached a pdf with all of my trouble codes. I was wondering if anyone had any experience with similar issues. The instrument cluster works but the oil gauge is a little jittery, I replaced the sending unit and it’s still the same. It has a rough idle and I tested for vacuum leaks, didn’t have any. I replaced the fuel regulating valve because the was fuel in the vacuum tube, still has a rough idle. The brake ABS light is also on. Could this be a problem with the ECM?
S3.pdf
I'd focus on O2 sensors and knock sensors.
Inspect the brake light switch and clean its internals if needed.
Clear the codes and see what comes back.
I don't see anything indicating a bad ECM yet.
Edited by asilverblazer
I agree replacing all of the o2 sensors will likely fix most if not all of the engine codes. Ordinarily “lost communication” with a control module means the module has failed, but with so many different lost communication codes, and the low voltage I would look for bad grounds and or alternator connections.
14 hours ago, Ray Mier said:
Hello,
Sign up for the shop manual at ALLDATADIY and follow the troubleshooting guide for the O2 sensor codes.  Avoid the temptation to throw parts at the car, gets expensive quick especially when 4 GM sensors are nearly $200.
Aftermarket sensors don't play nice with the computer system.
    • I have a 2026 base 1500 "WT" regular cab. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit? [I listen to classical and it gets a bit raspy at slightly higher volumes.  Don't need a sub etc.] Do I have two or 1 speakers in the doors? Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
