Hi Everyone, does anyone know of a good resource to find torque specs for our trucks?  I am looking for the following torque specs but haven’t been able to find any consistent info:
- Y pipe to header flange
- Transmission cross member bolts
- Transmission mount bolts
I am replacing the catalytic converter Y Pipe.  Most things I have read said good an tight but anything more specific would be of great help.  Thanks in advance.
Assuming you are 4.3, 5.3 or 6.2:
Y-pipe to manifold nuts - 37 lb ft
Exhaust clamp y-pipe to exhaust - 21 lb ft
Transmission crossmember to frame (4 nuts) - 70 lb ft
Transmission crossmember to transmission (2 nuts) - 41 lb ft
I wrote nuts because the torque spec should be applied to the nut not the bolt unless access prevents you from doing so.  GM writes them as such, spec applied to the nut on something like the crossmember bolts in where there is a bolt going through one end, and a nut on the other.
Something like a head bolt is a bit more obvious the torque is applied to the bolt head.
Edited by newdude
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
