My truck is currently at just over 95,000 miles and I am gearing up to do a tune up. My question is, what is recommended? Here is what I had in mind. Is all of this needed or is some of it "optional" as opposed to recommended.
Inspect brakes (should be good - I did them about 10,000 miles ago)
Drain and replace both differentials fluids
Spark plugs (do I do the wires as well?)
Transfer case fluid
Inspect power steering fluid
Inspect brake fluid
Transmission fluid and filter
Drain and replace coolant
Inspect air filter
Oil change was just done about 2000 miles ago
Inspect tie rods (did inner and outer in the last 20k miles or so)
So again, is all of that recommended, or is there some stuff that I can gloss over? I am open to all answers. :)
Truck is a 2014, 5.3 4x4. Everything runs fine, no issues or hiccups
Other modifications in case it matters:
High flow air filter
Borla exhaust with 3rd cat and resonator deleted
2.5 inch front, 2 inch rear leveling kit
Rough country UCA's
Doing the maintenance is the key to it lasting. Being able to do it yourself is an advantage. Cheaper and you choose the products to use.
Do it and do it more often, especially fluid changes.
Transfer case fluid
Inspect brake fluid
Inspect air filter
Rough country UCA's
I started making a list then thought. Get into your manual and find the "Severe Service" schedule. You're going to find several services are WAY past due. If you've never done the transmission, I'd bet the fluid looks like mud. Ditto diff's n transfer case. I'll leave the air filter to someone else. I'm not on the menu tonight. :crackup:
Edited by Grumpy Bear
Transfer case fluid
Inspect brake fluid
Inspect air filter
Rough country UCA's
Stick to your list and add a differential service, change the brake fluid, don’t bother inspecting it, it will be dark and dirty.
I have a 2014 w 86k miles on it.
im very happy with this truck, only planned on keeping it a few years but it’s been such a solid truck, I’m keeping it a while longer.
I replaced the spark plugs and did the trans service (along w changing a couple  of seeping trans cooler lines at 82k
Just changed the coolant (lots of horror stories about aging Dex Cool out there) and added. A bottle of Water Wetter because of the climate I live in.
Air filter gets changed annually as well as the AC cabin filter.
Noticed the plastic portions at the connectors near the fire wall on the 2 heater hoses are starting to turn brownish which means they are starting to deteriorate.
They will be replaced shortly.
Don't overthink it, just get it taken care of.
Thanks everyone! I bought the truck used with ~45k miles on it and from what I can tell by service records, only basic maintenance was done. (Oil changes, brakes, wipers, etc.)
I will plan to knock out that list - I plan to do it all myself. I don't think any of it is too bad, is it? I have done diffs on my older truck (04 Silverado 1500) but never done the trans fluid/filter.
Edited by Nbarr7655
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
