Gorilla Posted July 29, 2023 Posted July 29, 2023 (edited) Hey fellas, I have a 03 silverado 1500 2wd with a swapped 5.3 v8 and swapped 4L80e auto trans. Yesterday I found out I need a new transmission shifter cable. I got stuck and couldnt get the shifter out of park. Found out the plastic casting has busted apart. I've been looking at GM Part #'s 12477639(2wd) & 12477640(4wd) both on amazon are claiming to not fit my truck. Anyone know if the 12477640 (4wd), cable is longer than the 12477639? Being my truck was swapped to a 4L80e transmission anyone know if the 12477639 cable be correct cable for my vehicle? Would the 12477640 still work? I can find that one in stock. Edited July 29, 2023 by Gorilla
dna9656 Posted July 30, 2023 Posted July 30, 2023 How about installing a mega Shifter and be done done with the OEM cable hassle?
richard wysong Posted July 30, 2023 Posted July 30, 2023 if the original cable worked until it broke just replace it by going to a local parts store and skip the amazon BS
newdude Posted August 1, 2023 Posted August 1, 2023 On 7/29/2023 at 6:00 PM, Gorilla said: Hey fellas, I have a 03 silverado 1500 2wd with a swapped 5.3 v8 and swapped 4L80e auto trans. Yesterday I found out I need a new transmission shifter cable. I got stuck and couldnt get the shifter out of park. Found out the plastic casting has busted apart. I've been looking at GM Part #'s 12477639(2wd) & 12477640(4wd) both on amazon are claiming to not fit my truck. Anyone know if the 12477640 (4wd), cable is longer than the 12477639? Being my truck was swapped to a 4L80e transmission anyone know if the 12477639 cable be correct cable for my vehicle? Would the 12477640 still work? I can find that one in stock. You need 12477639 which changes to 19434388 which is why 12477639 is showing unavailable. 19434388 has plenty of stock.
Register a new accountSign in
