2011 GMC Yukon 5.3l, 194k miles. Recently started exhibiting long crank time and slow to start. The engine is cranking indicating the starter is working and the battery is  charged. If I back off the key then try again, the engine starts and runs fine. I did notice that the starter continued to crank without rotating the key past ON and I had to return the key to off for it to stop.
it’s either air, fuel or spark. I don’t have a fuel guage to check pressure at the rail but will pick one up if that’s an appropriate troubleshooting step. Does this sound like a fuel pump that is going out based on the mileage? I’m not aware of a fuel filter on this gen Yukon.
Any advice on troubleshooting sequence would be appreciated.
The problem with this generation truck is, there's a computer in the mix. Nothing simple like the earlier days of just power, ground, a relay, and the control side of said relay. That was too simple for automakers. They wanted to save a buck on fuel filters and return lines. Now you've got a FSCM - fuel system control module which varies output based on demand, which eliminates the return side of things.
Same things still apply to the pump - still needs good power, ground, and functioning check valves in the pump itself, but the computer throws a whole other world of possible failure modes. If the FSCM fails, you can't just replace it - it has to be programmed to the vehicle with a J-box and subscription (More $$$ to GM).
All that said, a long crank / slow-to-fire symptom is usually a check valve in the pump that can't hold fuel pressure when the vehicle is off. So, every time you turn the key to start, the pump has to refill that whole line again - that's why the long crank time. Air and spark have nothing to do with that issue.
On the point of what mileage things fail at, today, it's a complete crapshoot. Some don't even make it off the lot, while others go longer than the engine or transmission does. Nobody knows. It's the luck of the draw as to what you'll get. On my '07, that was one of the few things on that truck that lasted. Everything else failed during warranty, or before 100k.
Get a pressure gauge on there somehow and see if pressure is bleeding off whenever you kill the engine. If it is, you've found your problem, and the only fix is a new pump assembly.
EDIT: Just remembered on this one you can use the scan tool for fuel pressure, so long as the sensor is reading correctly.
Edited by Jsdirt
The condition is consistently occurring on cold start and there is a noticeable gas smell inside and outside the truck. I think this indicates a fuel pressure loss while sitting since it starts fine when warm. There is no sign of fuel leaking.
Any codes? If your smelling fuel, there should be an EVAP code either pending, current, or history in the PCM.
Confirmed: cracked plastic on the fuel pump assembly. Replaced the entire assembly and it's resolved.
Good deal.👍
Would be nice if GM could make a friggin pump that lasts. They used metal, it rusted. They use plastic, it cracks! You can't win today.
Meanwhile, my '86 Grand Marquis just turned over 300,000 miles on Wednesday morning, on the ORIGINAL in-tank electric fuel pump (and the ENTIRE driveline, minus the u-joints)! Was the 1st year of multiport injection. 37 years, 300k, ZERO LEAKS!!! Proof that it can be done. Automakers just refuse to.
Lately GM can't even get their 6.2 to make it to the first oil change without spitting rods out the oil pan!!
Edited by Jsdirt
  • 1 year later...
I have a 2013 Yukon gmc Denali 6.2 L my Yukon will start for a little bit then turn off can u please tell what is really wrong with my car
Could be any number of things from a fuel pump problem to the security system, and anything in between. If you recently had a new key made, that would be where I'd start. If not you'll need to get someone to do some diagnostic troubleshooting and then post what they found here. Too little info to even guess at the problem here.
I have a 2013 Denali having similar issue long cranks after sitting. Have replaced fuel pump twice plugs and wires twice and still have a long crank to start. Runs perfect once started and  I’ve noticed that if I press the pedal to the floor when cranking will fire right up.
I need some other opinions on possible causes. I’m almost convinced that it could be a bad injector leaking but don’t want to keep throwing money at it.
also just to add I do not have a gas smell outside or inside the vehicle. Just smells like it runs really rich.
Edited by Grift_40
Hook the truck up to a nice scan tool and see what the alcohol content is reading. If that value is way out in left field, it will start hard.
If all you run is regular unleaded fuel it should be reading right around 10% alcohol content. If the reading is way up around 30 or 40%, the alcohol percentage needs to be reset with a scan tool so it can relearn. I've seen this happen many times.
Not saying that this is the exact issue but you really should check in it because it will cause those same problems on the first start.
You have three variables: air, fuel, spark. Based on the quick start with the pedal comment, I would focus on fuel delivery first. Put a gauge on the fuel rail.
Flooring a GM vehicle puts it in "clear flood mode". Meaning it kills power to all the injectors. That tells me you've got too much fuel at start up - in other words, probably a leaky injector.
If you can get ahold of a bi-directional scan tool and a pressure gauge, you can perform an injector drop test to figure out exactly which one isn't holding.
Just to add to the above comments pull out the dipstick and smell the oil to see if it smells like gas a gas smell lean towards leaking injector or could be a malfunction fuel pressure regulator. Get it scanned for any code as said.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
