I have an AudioControl D6.1200 amplifier I plan to install in my truck (2023 GMC 1500 w/ Bose).  I am going to get the full integration harness from John at AIS.  My question is in regard to wiring to the amplifier.  Are the systems in these trucks 4-way or 6-way?  Obviously I understand that there are 6 speakers (technically 7 with the sub) and this should indicate it is a 6-way system, but I am unsure if the dash and front door speakers are fed by the same wires from the stock Bose amp (thus 4-way).
Basically, what it boils down to is...  using the harness that I will get from AIS, how do I properly wire it to the amp?
Also, do I need to get the ANC adapter?  If I do, does it completely bypass all microphone usage or is there a separate mic used for voice commands in the vehicle (like hands free phone) vs OnStar?
Hopefully all of these questions make sense and someone has some insight for me.
Looking for the same.
Would you have a link to the the t harness break out for amp instillation?
I have the Bose 7 speaker setup with the dash mounted sub.
He sends you instructions based on your amp and the harness he builds.  I just got mine from him, but I purchased the amp as well, so it is already wired.  The Bose outputs to each speaker, so I am assuming 6 channels (6 sets of wires).
