I recently purchased a 2014 Chevy Silverado LTZ 4x4 with the 5.3L V8 with 98k miles. Checking out the vehicle everything seemed great; 1 owner (old man), well kept, flawless interior and minor exterior flaws, drove great and made 0 abnormal noises when Idling or driving. I’ve reached the 1000 mile mark after purchase and the truck makes plenty of ticking noises at idle, slipping gears when applying low throttle and now the transmission light came on. See this is happening with so many of these trucks and I hate that I’m getting screwed because of it. I’m afraid the truck won’t be able to get me to and from work and I badly need help with this.
Caveat Emptor
Did ya pull the trans dipstick when you looked at it? Look at service records? Look for TSB's>
Anyone buying a K2 with a V8 and a 6-speed ought to be aware of the torque converter issues this combination has and the timing of failure events. Old boy got rid of it about on the money. As you've continued to drive it the pump is now likely toast as well. This is going to take a rebuild or replacement and I'd go for the later and a Florida Billet Torque Converter in stock stall. Welcome to GM trucks. 😉 DO NOT let them reinstall another 'factory' converter. Add more cooler and have a 70C TBV installed. It will outlast you and the truck.
Yep, gotta love GM and their low-bidder driveline components. They'll never change! Happened on my '07's 4L60E, happens with the newer transmissions & models, and is STILL happening with the '19 up junks.
If you plan on keeping the vehicle and need it to be reliable, you'll have to work through the failures as they come, and after doing some research, replace the parts with stuff 100x better engineered than GM could possibly muster in the 21st century.
I had to replace my '07's transmission at 103k miles after 3rd and 4th went up in smoke without prior warning. Fluid was still as red as the day I flushed it through, 50k miles earlier. I went with a PerformaBuilt transmission, and was VERY happy with the transmission, their workmanship & customer service. Not sure if they build anything above a 4 speed, but I highly recommend those guys.
Even if they don't, a phone call to them might get you pointed  in the right direction. Eventually they'll start building these, since there's going to be plenty of failures, and the 4L60 & 80E's are going to age out like the TH350 / 400 / 700R4 did.
    • I toggled my updates off a couple of years back. Since I don't have any CEL activity and the truck runs fine I'm happy to refrain from rolling the dice. I figure they've got it as good as it's gonna get. Recalls are another matter and I will strongly consider those if I get a notice in the mail.
    • We'll know soon. But at the end of the day they'll likely not take owner aggravation and costs into consideration. Probably the most important factor to them will be bottom line, along with units sold. Did they make money off sales of AFM/DFM-equipped vehicles? If yes, and the margin was large enough in spite of warranty and recall costs, I don't know that they will consider much else. Aside from government involvement of course, as in EPA and other regulatory bodies.
    • HM oils and cleaning. Well, soft deposits yes, perhaps. Like you say esters are present in in theory that should be a plus. But, is there enough? 🤔 The marker is the "Aniline Point" and it has to be pretty low to solve out baked on deposits. The softer sludge, yea, they do that and that is the claim. Valvoline R&P is the only HM oil I know of (Jury is out on Mobil 1's product) whose chemistry is uniquely able to remove the hard stuff and not be so aggressive as to swell seals to uselessness.    Oxidation levels in virgin oils blends is a good indicator of ester level and higher is generally a lower Aniline number and at one time we could predict without the $400 aniline test it's effectiveness. AN's, alkylated naphthalene doesn't show up in the oxidation test but does show in the aniline test and has become sort of a cheaper go to but most oils only add enough to solve the additive package. Not nearly enough to clean the harder carbon materials.   To your second question about does it matter. Yes is the short answer. Deposits are insulative. Those under the piston crown for example add octane requirement for knock free running. We don't' normally notice in todays motors due to Knock sensor driven ignition R-e-t-a-r-d. At least until the full slate of available values is consumed. Newer motors also often use oil jets to cool the piston to achieve tunes that would otherwise not be possible. Deposits on either side subtract from that. Deposits in fine screens used in VVT/VVL or DFM/AFM services live and die on cleanliness and screens are front and center. Vacuum pumps as well like brake booster in the K2's.    90% of todays oils are Group II+/III blends. A few more at PAO/AN/Group II's. A few boutique oils not Walmart shelf materials have enough solvency to prevent but not remove the hard stuff. R & P the current exception. Even HPL's EC30/40 used as directed (20% max) will get the soft stuff and some varnish out but not the hard stuff.    That orange varnish isn't baked on oil. Those are fuel varnishes left when the fuel diluted in the oil drops out when the oil cools. Like sugar does in a saturated mix of sugar and water that is put into the frig. That is ring sticking material and a glue the binds hard carbon sometimes.    Name brand shelf oils are intended to provide a useful service life at the least cost and highest benefit to the OEM who is trying very hard to keep you in $500 a month payment programs where the real money is made.   Did I miss anything you asked or left unsatisfied?
    • Yes, I understand. And I was saying (poorly), that it popped up on the DIC when I didn't have that info screen up. Just like you, but for a different maintenance issue. And just like yours mine didn't need to be shown at that time.
    • Ugh, amateurs.   But I did learn HM seal conditioners are esters.   I'm curious about deposit removal - some of the HM oils claim they really clean stuff up, the old and hard to reach stuff, and that's great? To Grumpy's point, a good oil should already be keeping the house pretty clean. I assume there are hard to reach places (underside of pistons?) and things that just accumulate baked-on oil and combustion vapors. If the deposits aren't friction or combustion surfaces and the deposit is just normal "seasoning", is it actually important to remove it?
