I just purchased a 2020 gmc elevation with 275x60x20 tires and want to upgrade to at least a 35 in tire and keep the same factory wheels.  Has anyone else done the same thing?  Most truck shops are having me either go with a 285 or install a 6in lift.
To achieve a 35" diameter in a 275mm wide tire you'd need to go with 275/70r20.  Tirerack.com did not produce a result when I searched for that size.  That might be why other tire shops are trying to convince you to go with a 285mm wide tire.  A 285/65r20 equates to 34.6".  285/70r20 = 35.7".  Imo, if you wish to do this, and not do a lift, to avoid/minimize rubbing I would go with the 285/65r20.  I currently have 285/75r18 on my stock Trail Boss LT and there is a little bit of rubbing at full lock of the steering wheel.  285/75r18 = 34.8", although Tirerack.com says the Goodyear Wrangler Duratracs in that size are actually 35.1".  That's what I'm running.  Taking a look at things, I plan on installing a 2" leveling kit the week of Thanksgiving and doubt it'll resolve the rubbing issue.  I have 1/2" wheel spacers ready to install, but just haven't had the time.  I doubt they'll fix the rubbing issue though.  I actually suspect they'll make it slightly worse, but I'm still going to try.  I did do a mud flap delete as I did initially have rubbing on the mud flaps.  That's another area you'll want to take a look at.  Bottom line: you don't need a 6" lift for 285mm wide tires, but you'll have a little bit of rubbing if you don't do a lot at all.  People will argue that last bit by saying they have tire XYZ and have no rubbing and no lift.  They might be right.  Perhaps it's all in the actual size of the tire make and model.  Nonetheless, for your application is go with the 285/65r20 tire.
Various 18" and 20" wheel sizes with their respective diameters.  Every size listed comes in a tire currently offered in either 18" or 20"
285 75 18 34.83
325 65 18 34.63
285 65 20 34.59
295 70 18 34.26
275 65 20 34.07
285 70 18 33.71
305 65 18 33.61
285 60 20 33.46
    mans44
    mans44
  • Who's Online   4 Members, 1 Anonymous, 437 Guests (See full list)
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
    • I don't recall ever dealing with one on an '06 and back. It may not even exist on that. I can't remember for sure.   Any kind of ice in or after the evaporator is normally due to low charge with both a clutch-cycling orifice tube system, and a TXV system.
    • Engines wear. It is unavoidable. So the question isn't if it will wear out but rather WHEN it will wear out. That question is about rate and RATE is a HUGE problem for almost everyone; but not in the way we may think.    Unless there is something drastically wrong with your powertrain, wear is exceedingly slow. It doesn't wear out in minutes or hours or days or months but in years or even decades. Ditto sludge and varnish. Humans are an impatient lot so to see the benefit of a truly superior product you may have to wait a very long time. Most will get bored first and trade before they reap the benefit.   Humans are not companionate creatures when it comes to those we do not know. We don't care what happens to the second or third owner as long as it doesn't happen to us or someone we know and actually like.   Sad commentary on humans but it is what it is. That thus, then, there is no advantage...to or for you if the above paragraphs adequately describe you.    BUT if you are a buy and hold type and patient enough to reap the rewards of your labors then that thing that is happening that you haven't yet seen, but will; can be abated by such products. Seals harden and leak with time and lots of it. Rings stick after thousands of miles of a slowly building plaque of varnish.    Then there is this. This didn't happen over night and this poor fellow knew when he removed the cover and not one second before.   Not "aware' isn't the same thing as "isn't happening".        The above was typical of the Ford 361 and 391 bus motors on Bulk Pennzoil Mineral Oil products on 3K mile OCI's at about 60K miles back in the 60's and 70's at the Anamosa School District when my Uncle took over their maintenance program.    This is Pepper at @ 165K on 5K OCI's using Group IV/V Full Synthetics.      HM oils will help the first but not the second.    Then again if one used..... ah, ya know.....
    • Thanks for coming back with an update.
    • Awesome you got it sorted! That's a new potential issue I'll have to mark in my book of issues. Thanks for the feedback.
