My 2019 6.2 AT4 started having a tick about 3 weeks ago. The tick started for about a week and then went completely away for another couple of weeks. The Tick started again today and I scheduled service next week. I have a few questions for those that have experienced the issue:
I've read on the forum and it appears the tick can be lifters or from an injector. Has anyone had anything else had other problems that caused the tick?
It seems strange that a lifter issue would simply go away for a few weeks. If a lifter fails it would seem to be a persistent issue. Has anyone heard of the lifter issue masking itself for a brief duration?
Are there aftermarket lifters that are known to prevent this going forward?
I heard there was a class action lawsuit on the lifters but cant find much about it. Does anyone know where it stands?
I have an extended warranty but in just about every case I've had in the past they've found a way to deny any claim I've made. If I have to pay for this out of pocket what will it run?
Thanks so much for all of your input.
Edited by Chris walker
Aaaah this can be a really bad problem. Search collapsed lifter on this forum. I would get your truck into a GM dealer right now. If it was my truck I would stop driving it and have it towed to a dealer. Collapsed lifters/lifter failure causing camshaft damage and possible engine failure is a known problem on the 6.2 and the 5.3L engines. I am not trying to scare you but lifter noise can be the only warning you get before engine failure.
Please keep us informed about this situation. Good luck.
I just picked up my 2019 RST from the dealership this evening. Exactly the same symptoms as the OP reported.... Collapsed lifter on cylinder #5, camshaft damage. A week later and 9800.00 bill I am beyond pissed at GM...
Take the advice of bikerjon
Very very sad to hear this. How many miles on your truck? No help from GM?
This is certainly not what we like to hear, Chris walker.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2019 Cadillac AT4 is having a ticking noise. To do so, please send an email to [email protected] with ATTN: Chris walker/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
Unless you have warranty why does everybody take their truck into a dealer for major repairs like this? You’re paying a much higher rate than you would for a good independent shop. For $9800 my DFM better be gone forever.
The easiest answer is probably major engine repairs aren’t common. They’re transmission shops everywhere. Brakes and oil change shops too. I’ve had one engine fail including all my hot rods in over 50 years. The one engine failure was just out of warranty they replaced it, I paid the labor. My favorite shop of over 40 years was my muffler guy and out of warranty repair guy. He didn’t do engines unless you bought one to him. No money in it. You had to be a friend or good customer.
No.
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 423 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
