fuel pump not working. found the black from the  4 wires going to tan plug bad, so  to the frame bad so replaced.
test light on the 3 pins tan (outside). purple (middle)  and black (outside):  with key on test light
power to middle purple only, using black ground (outside the 3 pins) to the frame. no power to purple or black/tracer
added 12 volts to the the plug going to the tank, power to tan pump runs with  60psi. does not run when power to purple or black w/tracer.
so the pump runs with power to tan, but truck is not sending power to that wire.
I'm thinking  the pump is good , but have a bad tan wire with no power from the truck.
any suggestions?
If I add a wire, where  would  I attach this to, the fuse box for the pump?
thanks all.
The pump does NOT get power with just key on,only 3 second prime when you turn it on and then while cranking. If it is indeed in the wiring you would go back to the relay. You can not go just Willie Nillie running power thru circuits to see what happens! The damage you can cause is extreme.
Edited by richard wysong
