Hello,
Does anyone know of a quality winter front for these trucks? I don't want to drill or modify the truck in any way. The ones I found online either require that or they have you glue buttons on the grill as attachment points.
My 03 chevy had a factory winter front that used felt hooks and that held it on. No modification was needed.
I'll bite. What is a winter front? You talking the curtain that block airflow to the radiator for warmer heat up?
On 1/17/2024 at 9:58 AM, Haufski762 said:
Hello,
If you need something immediately, cardboard ziptied to the grill will get you by.  However, I'm in the south and I have RARELY driven in conditions that required it, so I'm sure other people will have better answers.
7 hours ago, Grover67 said:
Does it have the factory louvers in the front of the radiator?
Yes.
They didn't do a whole heck of a lot when we had -30 out the other week.
My 22 HD came with the winter cover. Currently have it installed. Very easy to install. Has short straps with plastic hooks on them that go throught the grill and hook over the back side. I'm assuming that this is a GM part as it has the bowtie embossed in the middle of it.
I have yet to see one for a half ton.
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 503 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
