Anyone ever use a touch up pen?
I need to touch up a few spots but it is winter obviously so pretty cold in the garage. Would a space heater be sufficient to keep a reasonable ambient temp on the target spot?
Interested in feedback, thx all
I'd wait for warmer weather.
  • Thanks 1
I had a few chips on my roof (don’t ask) in December.  The temps were hovering around 3C- 4C.  No garage.  I used the touchup pen anyway.  It may not last but it’ll get me through the salty roads of Southern Ontario.  So far, it’s holding up.  I’ll check on it again in the summer.  For me it’s not really about having a perfect paint finish.  It’s just about preventing rust as much as I can.
thanks for the feedback guys - I'm thinking about testing preheating with a space heater and check the door (where the gouge is) temperature with a FLIR until it's ~85F. Once I can get that stable, I'm thinking I'll apply it.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
