Has anyone upgraded the seats in a late model SLE Sierra to leather or Pleather. Or found quality seat covers that actually fit right. Thanks
I just installed the Vertex custom covers on my SLE a week ago. Cannot comment on durability but overall the fit is very good, the center console seat is the only spot I am not totally happy with. Overall they are a big upgrade over stock.
Apologies for the sideways photos but hopefully they help show how well the covers fit. Probably took 4-5 hours to install everything completely and being pretty picky.
They took almost 10 weeks to ship but I bought them on Black Friday sale so I think the were out of stock before my order came in.
20240125_132541.thumb.jpg.722c202e5b5f9460bd2549fca72e91a2.jpg20240124_142643.thumb.jpg.4bbae7fde60f6605d71d52bae22b5ece.jpg
i have the same ones in my reg cab, love them. i actually bought them the day i ordered my truck so they sat for about 100 days before i evan had the truck. most people that see them dont evan know there covers they fit that good.
I found a full set of oem leather takeoffs on ebay for $400 I believe and replaced my cloth.  Took some time and effort to remove each seat and swap from cloth to the leather, but I'm happy with the end result.  Wife's not real happy because we don't have seat heat, but she'll get over it.
I actually ordered some leather seat covers for my SLE. Super satisfied with the fit and quality. I went with Katzkin.
Me too, love them.  Nobody realizes they are not stock because of how flawlessly they fit
  • 9 months later...
How did you get the rear seatcover tucked under the headrest trim? The front headrest trim comes off, but the rear headrest trim doesn't appear to come off and the pre cut holes on my new vertex seatcovers are barely bigger than the headrest posts and no way will they stretch over the trim. I am hesitant to cut the holes bigger and assume there has to be some way to remove the trim pieces. Any help here is appreciated so I don't have to call vertex customer service
https://youtu.be/XVCSqkwSG_E?si=cE6RAVeW2u2zCZdG
Now I have a similar problem putting the covers on the headrests. The pre-cut hole for the tilt button on the headrest cover is way too small to stretch over that button. If I could take that ring off that's around the button, the cover would go on so much nicer. All my searches come up with is how to remove headrest which I already know how to do.
Any ideas?
PROBLEM SOLVED. I WAS ABLE TO STRETCH COVER OVER THE BUTTON WITHOUT DAMAGING THE NEW COVER.
THANKS
Edited by Grant S
problem solved
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
