Is there someone that works for GM that can a question about my information system.  I have a 2024 Pro with up graded stereo but does not have 360L that would give me the ability to pause, rewind or FF my Sirius. I call sirius and they said it was a GM thing in the stereo package, no one makes a after market stereo yet that would offer that option.  So my question is can I upgrade my info center or is it possible to reflash what I have to asses 360L.
You might want to look into aftermarket help.  There are companies that work on GM equipment to provide options to customers.  I recommend White Audio and Media Services (WAMS).
There will be nothing GM can do or supports.  As far as factory goes for 2024, the IOK 13" radio supports the 360L.
You can try WAMS, but I only see they have an IOS to IOU upgrade.  The Pro uses the IOR 7 inch radio.
2021-2024 (T1) SUV & 2022.5+ Pickup (Global B) - White Automotive & Media Services (whiteautoandmedia.com)
Edited by newdude
16 hours ago, Mark57 said:
So I'm not sure about the different radios would I be able to buy the IOK 13" and hope its a plug and play. Thanks
Sadly no that is not plug and play the wiring is completely different along with a bunch of other software and modules etc.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
