Ok, so here we go.
2005 Sierra 2500 HD 6.0 4L60E
471k miles
I know for a fact that I have less than 60 psi compression on 1, 3 & 8.  Is there anything I need to specifically look at other than valve train and or possibly rings?
So, roughly 6-8 months ago I noticed the oil pressure was low, like low enough for the DIC to display low oil pressure at idle. I've went from 5-30 to 10-30 only to have the oil pressure to sightly increase.  I want to say that I'm about to be replacing the oil pump, but is there anyone that thinks the filter screen under the oil pressure sensor would cause this?
I love the truck.  It was a retired company truck when I bought it.  Yeah, I know, it was road hard and put up wet pretty much.  Just looking for advice on where to go from here, and looking for good used 6.0's are rather expensive.  Thanks in advance
Edited by Robs05hd
spelling
Welcome to the forum! With that amount of miles on it it is due for a complete rebuild. Could be excess bearing clearances causing the low OP. Might be more economical to look for a parts truck than an engine or try LKQ yard if there is 1 in your area
Edited by richard wysong
A worn out pump or loose fitting pick up tube o-ring could be the cause for low pressure if the main/rod bearings and cam bearings aren't worn out. But honestly the cam bearings always look worn on high mileage engines. You can also dump an extra 2-3 quarts in the oil pan as a test, the extra oil will bring the level up to the pickup tube o-ring and if the pressure is higher, that is likely the cause. Only let it idle doing that, the oil will be pretty high and you don't want the crank slapping the oil as it flows to the back.
Low compression can be from rings and or worn out valves. If you are going to do a in frame service I'd pull both heads and have them cleaned up at a machine shop. Dingle ball hone each cylinder and buy a new set of rings. Slap it back together and see what happens.
Edited by CamGTP
OMG.  You ran it for 6 months with low oil pressure, and you are just now going "Should I do something about it?"...
And thinking it's just the oil pump. Jebus.
The motor needs a rebuild, and I'd at least pull it to do all the cam bearings, and measure the cylinder bores to see if they need to be bored over.
11 hours ago, Robs05hd said:
Ok, so here we go.
471k miles
An entire rebuild.  That's what you need here, nothing short of.
An oil pump isn't going to fix 60psi of compression.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
