Just recently bought a 2018 Sierra 1500 4.3V6 with the 6L80, 91xxx miles. A week or so later I ordered my AFM disabler and the GM updated TBV. Normally my trans temps would be 190-210 city driving, 170-185 highway.. took a while for it to be delivered through snail mail but when it finally got here I went ahead and swapped it out. I noticed that the trans fluid would reach 180s about after 20 min or so of highway driving( its been high 80's here these past few days). It definitely takes longer for the fluid to reach these temps but I was expecting way cooler levels.  After driving on highway for half an hour(185 F), I drove around town  and parked at grocery store and watched the temp rise to around 193 F at idle, shopped for a few minutes and when I started the truck again it was down to 185 F and pretty much remained that temp for the 10 minute drive home stop and go traffic.
only one previous owner and had excellent service history on carfax, regular oil changes and one Transmission fluid change at 45k miles. I'm waiting on my filter. gasket and fluid to be delivered some time next two weeks to change out the fluid myself. Transmission runs fine to me .
any ideas why my trans temp is so high?? anyone else have a similar experience with the GM TBV update?
I should also mention the i went ahead and ordered the STL010 from Shift Tech, hopefully that continuous flow will give lower temps
Edited by gmm43
10 minutes ago, TheRiver said:
"Active Grill Shutters"???
That would throw a code.
Your transmission thermostat change only drops the 'open temp' by about 20 degrees, IIRC. the pill flip or thermostat delete is a constant open & cooling of transmission fluid. I did the pill flip 3 years ago on my 17 & I don't usually see it above 140-145 F. It cools fluid like the older 4L80 transmission. This transmission thermostat is GMs way of trying to get more MPG due to EPA at the expense of the owner when torque converter goes bad & takes out the transmission. IMO
Wow really? honestly I chose the GM update only because of how easy it would be to just switch out the original one. But Im definitely going to install the STL010 kit I've got coming tomorrow. It basically keeps the the valves open to have the fluid go through the cooler all the time witch in turn is basically functioning as a delete. all I need is a pair of snap ring pliers ..
Thanks
Thanks
In my opinion you won't be sorry. I'm not. My 6L80 is a weak transmission or maybe the factory torque converter. Lowering the transmission temperature along with frequent fluid changes may increase its life.
Its because you have the 4.3.
The 4.3 has the transmission cooler built into the right hand side tank of the radiator and that's it.  The V8s of the same year as yours, they have one cooler that is out at the front in the top of the AC condenser and do not send any ATF through the radiator at all.
Here's the line routing for the 4.3.  Out of the transmission, if I recall it should then be in flow to the bottom and then out from the top and then returns back to the transmission.  Being it goes through the radiator only, the ATF is still being exposed to the coolant temp in the radiator itself so it maintains a higher temperature.  A 2018 5.3 for example however would run 145-170F with the lower temp TBV.  Mine ran no more than 170F on a hot day romping on it.
Your best bet to bring them down will be the SureCool bypass, but even then don't expect a larger drop.  You might see 10 degrees lower or so, maybe 15.  Your truck with the SureCool would operate temp wise like a 1999-2013 truck would as those all flowed through the radiator only on a V6 and V8s that did not have the heavy cooling, but even those that had heavy cooling (which had an aux cooler) still flowed through the radiator first.
@newdude nailed it. To get a lower temp without additional cooler you need to lower the water temp. I run and IPSCO thermostat housing and a Reische Racing 170 F thermostat. Plus Red Line D6 fluid which has both a higher thermal capacity and thermal conductivity. Not sure they still sell that unit but STANT still sells a 180F that fits this holder and Katech started selling a 174 F unit that fits the stock housing. Yellow line is the one I'm currently on. 170 F water and 70 C TBV, Ancillary cooler is in the works. 😉
Road speed is also a huge temperature driver both to fast and to slow.
Sitting parked or in town when there is no flow over the radiator and water temp rises well above the water thermostat set point will still drive temps up. The fix for that would be additional cooler with a separate thermostatically controlled fan.
Thanks for the diagram and explanation! will definitely install the Sure Cool
very cool data! I guess for now my next step is an after market thermostat, after the Sure Cool mod. you would think that they would have the same tranny cooler on V6s as like the V8s since the V6s also come with towing package
Less towing capacity, less engine to cool.  Even the older V6s didn't have a factory aux cooler.
I ran a "pill flip" before installing the 70C TBV. The blue and orange lines in the top graph. The 70 C TBV is a pretty comfortable 'floor' for temperature and has nearly zero impact on the hotter days. Sure Cool is like a pill flip and the insurance it provides is more smoke and mirrors than actual. If you plug that stacked plate exchanger in the cold tank you've already grenaded the transmission.
170 F on the water requires zero tuning. A 160 F stat however does. Too cool anyway.
Even if you faithfully duplicate my system you will still have days of high fluid temperatures. Stalled in traffic for example. Crawling for a hour on a hot day around a wreck on the I-80. Pulling heavy over a steep grade. Thing just needs more cooler to take the head off the snake. i.e. quicker cool down and more reserve. Just say'n.
could you say that in layman's terms?😅
I just installed the SureCool today after work. truck was still warm by the time I finished, trans fluid temp read 187. I ran a test drive to the  car wash going the scenic route. 10 min on the free way and plenty of stop and go city driving, letting her eat a couple of times.
Good news? It never hit 200...only went up to 199 and settled down to 194🤔. I'll keep an eye on it in during the morning commute to see what happens when starts from ambient temp.
To plug the cooler and REQUIRE a bypass it would have to be filled with trash.
You can't get the fluid cold enough to gel it.
:P
    • IMNTBHO;  the worst thing for the 6L80 is to be lugged down to low engine rpm while in high gear......AKA, to save fuel.   I rarely use D on my '16 with the 6L80 and use M mode to keep engine RPM above 1500 at the speed I'm driving, which is also benefiticial for the tranny because line pressure is kept up because the pump is actually turning a decent speed, and it's not always hunting to drop to the next gear to lower the engine RPM's.   Never above 30mph.............M3, maybe M4 if just driving thru a small NoDak town Never above 40mph............M4 Never above 50-55mph.............M5   This is way better for the tranny and the engine.........especially if AFM is still active.   262K miles on my OEM 6L80 as I type this.
    • If they had nuclear material for "11 nukes" we'd have seized it.    Our military has been rendered either too weak/dumb to seize it, or they don't have it. Your pick,K-nut. Because right now we're fighting over who gets to toll oil tankers in the strait.    I hope you're man enough to admit you've been taken for a ride when it's finished.
    • I hope you’re man enough to admit that you were wrong when it’s finished.
    • And you're obviously full of it too.  Apparently anything he does is perfect to you.  Don't you think this whole ordeal would have been better if he had maybe thought it all through first before bombing Iran at the request of his bffs in Israel, Saudi Arabia, and Qatar?  They are the ones that had the biggest issue with Iran.  Thus they have been pouring the platitudes and giving gifts/bribes to him.  Had he thought about the consequences of what would happen to the Strait before starting anything, we wouldn't have this issue.  Now he is stuck with no way out of this mess.  But you have your head stuck way deep in his rabbit hole to see anything else.  So no, I don't have TDS.  I see what he is.  The derangement is yours from no oxygen in the rabbit hole.
    • Bringing of the fact that every President has said the same thing. They can’t have nukes. I guess you missed that before epic fury they said they had enough product for 11 nukes and weren’t giving it up. That not political or polarizing. The opposition of that is and giving aid to the enemy. The mandate is decades old through many administrations. The difference is TDS.
