I have a 2017 Silverado 1500 with the 5.3. Had misfire on cylinder 4 and p0172 and p0175 codes, had alot of fuel in oil, replaced the HPFP and misfire went away as well as a tick to the engine. Fuel pressure was bleeding off and replaced in tank fuel pump now it hold 80psi. Truck is running better and after resetting fuel trims they have smoothed out and are reading at 0 on both banks.
The truck is still not running right and can hear a tick on bank 2. Ive removed both valve covers and cranked the engine over and everything is moving, didnt see anything wrong with the valvetrain. Im not getting any codes either.  The rail pressure is bouncing from 450ish to 750ish, where as on my 14 sierra it stays at 690psi dead on commanded. I notice the fuel temp is also reading at -40 but on my sierra it doesnt show a reading for fuel temp. Is there a fuel temp sensor? Could it be the FPCM causing the erratic rail pressure.
truck has new plugs and wires, fresh oil change, high and low pressure pumps, new tensioner
80 psi is really high for the low side fuel pressure. The fuel pump control module should be controlling the pressure based on demand. At idle it's only going to need 42-45psi on the low side and it should bounce between that 45-60psi while normal drive and may spike above that at wide open throttle.
When keyed on or priming the system the pressure goes upto 80 psi, at idle low side is at 45-55 psi. I’m wondering what would cause the high pressure to vary so much. Commanded is 600ish but it bounces around +\- 150 psi. (25%) which in my mind is huge.  My 14 sierra holds steady at 690 psi (commanded is 690 psi). Can I swap fuel pump control module with my sierra or do they need to be programmed?
is there an actual fuel temp sensor?  I’ve read it’s part of the rail pressure sensor. But can’t find any confirmation. I don’t want to throw parts at it.
So I remove valve covers again and found #4 push rod bent. Replaced the push rod and took for a road test. Ticking has gone away but fuel pressure commanded is 580 and is still anywhere from 475 to 610 psi.
fuel rail temp is still reading -40.
any ideas? Fuel pump control module? Fuel rail pressure sensor?
  • 8 months later...
Have you found your issue? I have exact problem with erratic rail pressure
We regret to hear that you are facing concerns with your vehicle and would like to investigate further on our end. Please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We will watch for your email.
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
