Im looking at getting the flashpaq by super chips and running the 87 tune and disabling the DFM BS.  Has anyone done this?  I’ll be doing this in a 2020 GMC Sierra 5.3 10 speed.
My main concerns are Illinois emissions and towing.
I’m wondering if I will fail emissions or get a “not ready” status running this tune with DFM disabled?  I’m also wondering if it’s ok to tow with that 87 octane tune.  The one video I watched on it said it’s not for towing for some reason.
Just wondering if anyone else has gone this route and can answer these questions and maybe give me some honest feedback about the flashpaq.  Thanks.
Matt,
I have the Superchips Flashpaq. I ran the 87 tune for one tank, and I will tell you it is not worth it. The tunes will not affect emissions, but if you are considering using it for towing, use the "tow tune" and run the higher octane fuel. The 87 tune will likely not get you the performance you want.
For context: I have a 2021 GMC Sierra AT4 with a 5.3 10 speed. Exceptions - I am running a Fabtech 4" lift, 35x12.5x20 Toyo AT3 tires, Cold Air Inductions CAI, and the Borla S-type exhaust.
Flashpaq bonuses: the button memory is great; it disables all the silly things you don't want a V8 to have. The calibration for tire size is pretty much spot-on. The pedal sensitivity adjustment is enjoyable, but it can decrease fuel economy due to the fun of it all. My "real world" numbers on 93-octane and the performance tune: average of 425 miles to empty on fill up; 17-18.5 mpg by hand and on the computer (400-mile distance calculation), and incredibly fun to drive.
Respectfully,
Doug
49 minutes ago, schwingaling said:
Matt,
Respectfully,
Doug
Appreciate all of this info Doug!  Thank you!
1 hour ago, schwingaling said:
Matt,
Respectfully,
Doug
Hi, so is there a HP/ TQ  gain with this in the performance tune or is it just the throttle sensitivity?
Is the the one that has the "locksmith" to unlock the ECM and the TCM?
The performance tune has a modest HP/TQ gain in addition to the throttle sensitivity. The "performance" tune is more HP than TQ, while the "haul" tune is TQ-focused. The power increase is not as drastic as the numbers you are going to see with the 6.2 (which are the numbers they advertise), but I have no issues with get-up-and-go running a lift and 35s while doing truck things. For the 5.3, it definitely increased the joy of driving and seat-of-the-pants performance.
It is important to note the "performance" tune is not for hauling, but with the ease of switching tunes, it is not a terrible headache to switch when I need to haul something (which is not very often and planned well in advance).
Yeah, you have to send the ECM to the company (Holley is the parent company, I believe) to have it unlocked to work with the handheld flash tuner. It was about a 72-hour turnaround.
My only concern now is whether or not I am able to add a supercharger since another company unlocked the ECM. I am going to send inquiry emails to tech support at Magnuson and Whipple to see if I can use my current ECM or if I need to get a new one for the supercharger tuning.
Update: You no longer have to send the ECM to the company for unlocking. They sell the FlashPaq with Locksmith device, which allows you to unlock everything in your garage using the hand tuner and update software via your personal computer. The new system (2849-F) allows you to unlock the TCM previously unavailable on the older FlashPaq tuner for the 19-22 Sierras. This is great because, depending on what tune you used, some of the shift points would be a little off (surge/holding high RPMs when not accelerating).
I have reached out to Superchips to see if there will be a kit/software update for those of us with the older FlashPaq (2847-S) so we can benefit from unlocking the TCM and correcting some of the shift issues.
website: https://www.holley.com/products/tuners_and_programmers/handheld_tuners/superchips_f5_flashpaq/gm_flashpaq_with_locksmith/parts/2849-F
website: https://www.americantrucks.com/superchips-sierra1500-flashpaq-f5-tuner-locksmith-2849-f.html
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
