Hello,
I have a 2020 GMC Sierra 1500.
I recently received an error message saying service brake monitor. It appears that I had a defective brake calliper and one side had an extremely low pad. The sensor itself was detached and dangling.  So, I replaced the front brakes and sensor cable yesterday. I neglected to put it into brake service mode at the time. I’ve since turned the brake service mode on and off and attempt to troubleshoot my problem.
When I go into the break life monitor, there are three options: front brakes installed, rear, brakes installed, and disable.
None of the options are greyed out. Nothing happens when I select front brakes installed or rear brakes installed. The only thing I can change is enable or disable.  when it is disabled the service break monitor error message no longer pops up.
there are no service codes when I do a scan. I could disable the whole monitor and pretend like everything‘s OK but I paid $45 for the cable, I might as well have the system working as it should.
I hope somebody has some suggestions. Thanks.
  • Confused 1
I had this same problem, I have a 2020 GMC sierra 1500 Elevation. The service brake pad warning came up I brought it to the dealer and was told I had plenty pad left but that the sensor was grounding out and in order to replace it I would have to change my brakes. I just disabled the message. Now at 26,000 miles only I keep hearing a scrapping noise took off the rear calipers and noticed that my outside pad was still had a lot of life in it but the inner pad was totally gone. I think it has something to do with the electronic Parking Brake. Not Happy about this, now I need to by new rotors and brake pads for the rear. Iv had truck that I did not have to replace the brakes till 50,000 miles.
  • Sad 1
Ya ran into the same issue when I replaced mine and couldn't reset the life monitor. Checked with a couple of local shops but they had no clue. So bit the bullet and checked with the local dealer and they got right in and reset it. They say GM does it as a safety issue and only wants dealerships to reset it.....crap
That sucks. I thought this monitor was going to bring piece of mind and ease. It’s done the opposite.
I was afraid that was likely going to be my only option.
Things just seem to be harder and harder.  GM is doing everything they can to suck money out of the customer.  I couldn’t even get the caliper from my two local auto parts stores. They couldn’t even get one.  My truck is a 2020. It’s not that new.
The whole thing is scam perpetrated by GM.  And what do we get here, a random supposed person from customer service, but no real action on anything.  Just look at the guys thread where his tranny is overheating.
  • Sad 1
Supply issues are still a issue hard to imagine that it is...
I went with new rotors and pads(aftermarket) all the way around @ 30k.  Pad life was showing 88/90% and they had alot of pad left but I was getting vibration issues from the pad material imbedding on the backside of the rotors, due to what pad material gm has to use anymore.
  • Sad 1
Hey folks…
I finally resolved my issue without having to go to the stealership.
I used a tip from a user on Reddit. It wasn’t a suggested solution to my specific problem but it lead me to fixing it.  It was a combination of his advice along with my own steps after.  I would give him a shout-out but my screenshot missed his username.
Anyway…. Maybe all of the steps are unnecessary but it worked so that’s all that matters.   Here are the steps I followed and added more of mine to the end:
With vehicle running, Put the truck in brake service mode. (Hold the brake and Parking brake button for 15-20 seconds until the P flashes yellow. Then release both and quickly press the parking button again. It should continue flashing.)
Then turn off the ignition.
Disconnect negative terminal of the battery (10mm socket).
Pump the brakes to seat the pads. (depress the brake pedal as far as you can, wait a few seconds, and repeat 10x or so)
Reconnect battery.
Leave in service mode while connecting an OBDII and do a scan.
Take it out of service mode. Run another scan, it should only show a MIL sensor now.  (P25A2)
NOTE: Mine never had any error codes at any point.
Delete the MIL code from stored and pending. NOTE: I still never had any codes so I ignored this step.
Immediately turn the ignition off.
Press ignition button for 5 seconds or so until full accessory mode is on.  (Not just the basic accessory mode).
Scan with your OBD2.  Erase codes even if none show up.
Turn vehicle back on and you should be good to go.
I changed my brakes last Friday.  I couldnt reset the brake pad life monitor.  I purchased a topdon Artidiag500 scanner and was able to reset it this way.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
