15 minutes ago, 84bluebody said:
Looking for a source to replace check engine light unit on 1984 GMC Sierra Classic K1500 California requirements
remove the instrument panel and replace the 194 bulb. Welcome to the forum!
Edited by richard wysong
Hi appreciate your answering. This maybe a California thing on the dash. I am looking to replace the rectangle square built in the dash in front on the light bulb that says check engine light. I have one its just a little frosted and since i refreshed everything else i thought i would replace it. Cannot find it anywhere. The new dash i bought from LMC truck has the outline on the backside for the rectangle but will have to be carefully cut out so i  will have a visible check engine light warning.
    • 2026 3500HD.  Mostly empty. Grocery getter. What tire pressure are you running for 37x12.50x20. I have 37x12.50R20 Toyo Open  Country RT pro and been running around 55 lbs front and rear and it's too much. Tires are wearing more in the middle. Toyo says 45 front and 50 rear. Chalk test and it's still too much. I lowered it to 40 front 44 rear see what happens.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
