Hello everyone I purchased illuminated door sills from shopchevyparts and of course upon arrival it did not come with installation instructions but I was able to find a thread that has the proper place you need to connect the wire to power them on. My problem is the door sills that I purchased did not come with the connector that is supposed to go into the BCM. Does anyone know what kind of connector I need to attach to the wiring to plug into the BCM? The threads that I’ve found on here of members that have the illuminated door sills have that connector already in the wiring of the door sills. The photo below was used from another thread but that’s the connector I need. Any help would go a long way thanks!
If you have any connections with a dealer you may find one of these Molex connectors in a scrap harness. The 24 HD trucks use this connector. You would need to de-pin one from a harness.
Use cation when putting it in the new connector that the lock tab is facing the correct way.
Edited by 64BAwagon
