11 hours ago, Todd Sickler said:
So I was gifted an Android Ai Box Ultra for Christmas and I cannot for the life of me get the full screen. Any help would be much appreciated. It’s an Android box that allows CarPlay and Android Auto, but I can’t get the Android Auto to work with my IPhone obviously, only the CarPlay.
Here is the link to the box.  https://a.co/d/7gbIiyA
I’ve attached a picture too. image.thumb.jpg.5ac788856c26e6bf2548d00144552268.jpg
I’ve contacted AuroraLink (the seller of your Android Ai box to find out any info on wether it is possible to change the projection method to use Android Auto instead of CarPlay (allows the use of full screen). They should get back to me in 48 hours, maybe a little more because of the holidays. When I find out more, I will let you know.
Hey, thanks man. I’ve watched Don’s Life on YouTube showcase this item and he’s got it hooked up to an iPhone with CarPlay and he’s projecting full screen so I know it’s possible I just can’t figure it out. My truck is a 2022 GMC Sierra 1500 refreshed by the way.
This is the response I got, I’m not sure what they are talking about in the middle but I emphasized the key words.
Dec 31, 2024 12:22 AM
Hello
I am your exclusive after-sales service, and I will give you an answer to your question: The CarPlay channel is currently used, and the wired Apple CarPlay display area is the display area of our car box, and switching to the AA channel is not supported.
Hello guys new to the site just purchased a 2025 gmc Denali and love the truck but would like to get the full screen to work with the carlink tbox plus box to work.  Can some one direct me to the link to install on the SD card to work.  Thanks again
Much easier way to do this. Instructions are below
How to Get Full-Screen Apple CarPlay in Your GMC Sierra (Should Work on All Models)
Purchase this device from Amazon: https://www.amazon.com/dp/B0CX464S74...
Unpair your iPhone from the truck.
Plug the device into the center console USB-A port. It will connect through CarPlay using a wired connection and will initially display in half-screen mode.
Accept the generic agreements for CarPlay.
Connect to Wi-Fi (either your phone’s hotspot or another network).
Go to settings and update the device.
Once updated, connect your iPhone via Bluetooth.
Using the supplied SIM tool, press the button inside the hole on the front of the device (located between the two status lights). Hold and release after 2 seconds.
A pop-up will appear on the screen asking if you want to switch to Android Auto mode. Select “Yes.” The device will reboot.
You should now be in full-screen Android Auto mode. You can stop here if you prefer Android Auto, which is quite good as it supports video apps like Netflix and YouTube. You can set up your phone to automatically turn on the hotspot every time you connect to the device, ensuring seamless tethering when you get into the car. Continue for CarPlay setup.
Go into settings, click “Other,” then click “Boot Up App.” Set it to Autokit (wireless CarPlay).
Done! Now, when you get into the car, it will automatically start up Android Auto, followed by the wireless CarPlay app. This process takes about 7 seconds with no intervention from you. Performance is excellent even though it is wireless. Enjoy!
Binize Carplay Ai Box Android Auto Ai Box Wireless CarPlay Android Auto with Video APPS 4G+64GB,8Core, Android 13,Only Support Car with OEM Wired CarPlay/Android Auto Just in case the link stops. You need a AI Box that can output as Android Auto. That's it.
FYI, I did this and it worked flawlessly.
I have a 2025 Silverado and I follow all the steps and get to the android connect to Pixel and the box flashes blue but says it can’t connect. Any suggestions
Not sure why it’s not working for you. Make sure you’re following every step to a tee. I had to do it a few times before it would work for me. I think it took 2-3 tries, but it finally connected and works flawlessly.
18 minutes ago, Hammy2500 said:
Does this work for all boxes? I tried it on my magic box but didn’t work.
No, it’s specific to the one I listed.
I bought the box Todd suggested and was able to get it to work full screen. Mine won’t start automatically though. I have to unplug and plug the box in every time I start the truck. Not terrible but it would be nice to get it to start automatically. When I start it it tries to connect a Pixel phone and on the GM display it asks me to accept something in the Pixel phone, of course there is no Pixel phone so I can’t accept it. So I hit cancel and then select the android device in the “phones” section of the screens menu and then it works. After a few minutes it will give me an error saying it won’t connect but I just select it again and then it works fine.
This is my second box like this, I had the Stream to Your Car one at first. It started acting strange and would get really hot. This Binize one is much better I my opinion. It’s a little cheaper and Amazon has a $60 off coupon right now.
Edited by Velocity12
I just picked up this box, and it seems to work well.  It isn't showing the navigation on my heads-up display, though.  I've sent a message Binize asking about the configuration.  Any suggestions while I wait?
Update--- they just confirmed that the heads-up is not supported.
Edited by IndyIN
Update
Quick update and issue. Got everything to connect and everything worked perfectly. Then today I started the truck and a pop up said can’t connect to android auto because date and time not in sync with the truck?? Now it’s a red brick sitting in my truck because no matter what I update automatically or manually with the date and time the same pop up keeps…popping up
Sorry for the delay. Looks like you figured out what I did with them. Unfortunate. I wonder if it will work in CarPlay mode instead of using the Android platform. I’ll try later.
this is strange. I haven’t ran into that. Have you tried unplugging it, resetting it and trying again? Mine has not given me any problems at all.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
