Does anyone know the PNs for the oil pan & transfer case skid plates on the 2024 HDs w/ the 6.6 gass motor? TIA
4x4 models:
Plastic Steering Shield: 84154539
Z71/X31/AT4:
Oil/Engine: 84154831 (4 bolts needed)
Transfer Case: 84154540 (3 bolts needed)
ZR2/AT4X:
Front (replaces plastic steering shield) steering/oil/engine: 85637479 (4 bolts needed)
Transfer case (requires rear holes drilled for 20-23 models and *possibly 24+, unconfirmed*): 85569359 (4 bolts needed, 2 may need to be custom length with nuts/washers for 20-23 models drilling the crossmember, 24+ might be pre-threaded need confirmation)
Bolts for all (M10X1.5"X25mm): 11518341
Thank you. The truck the dealer found has the True North Pkg, does have the skidplates, so I wont be needing to install them myself.
On 9/10/2024 at 6:38 PM, Epsilon Plus said:
On second thought after seeing the ZR2 lift thread I may go w/ the aluminum skid plates. Thanx
