I searched for this topic before posting so hopefully I'm not reposting.  Had my truck since end of August 2023.  Rearview camera mirror has worked perfectly until this issue started about a month ago.  Still works great during the day but horrible at night.  The less light the worse it gets.  Just wondering if anyone else has had this problem.
Haven't seen / heard of that one before.
Hopefully your not over miles on the warranty.
Does it work ok with camera mode off?
Should function like an auto-dimming mirror when camera mode is off.
Edited by redwngr
Yes, it works fine when not in camera mode.  I'm still under warranty.  I'm going to bring it in.
Let me know what answers you get… I’m going through something similar. But it has to do with glare/starburst like images at night, see photo.. I’m still under warranty and dealership is giving me a hard time.. I did a Reddit post all about this. Again, lmk
Edited by Whatwasthat
We have 2 vehicles with camera rear view mirror.
They both work, but we run them with the camera off.
Try cleaning the lens with window cleaner. Don't just wipe it off with a dry rag.
Lens isn't dirty. Dealer installed brand new camera that's by the third brake light housing after showing them the photos thinking it would solve the issue (and i hoped so too). But It didn't and now they're refusing to do anything further, saying since they installed a new camera this is how it should normally look.
I'm like, seriously guys?!? Like I bought the truck new, I KNOW what's its suppose to look like. Service it saying it normal. effin crazy. now i'm left trying to find used 2022s in my area and do a test drive at night and shoot photos for them.. absolute nonsense..
Man that’s disappointing.  It’s 4 components for that camera mirror.  The camera, a harness that goes from the camera to the inside of the cab.  Then another harness that runs alone the headliner.  And finally the mirror/screen.  If you get somewhere with the dealer, maybe push for a new mirror/screen replacement?
I hope the dealership replaces the unit for you. I generally don't drive with my camera rearview mirror on, I guess I'm scared for if it goes bad. But at the same time, I do find it awesome when on a multilane highway it basically cleans up the the blindspots around the truck. Ever since I tinted all my windows again, and in the rear back half from factory It's removed all the glare from interior lighting to the windows, so I just roll with that versus the camera rear on at night, or most of the time.
Can anyone post a pic of what theirs look like at night maybe at a stop light or something? something I can use to show the dealer
Have you played with the mirror camera 'brightness' and 'zoom' settings?
Mine doesn't seem as bad as what's in your picture, but it definitely has some 'hallowing'. (if that's the term)
Hallowing severity depends on ambient light and of course the type and aim of the lights of the other vehicles.
In camera mode it the road behind appears more like in daylight (and of course this changes with brightness and zoom settings)
I use it in mirror mode because mirror mode view is crystal clear and without hallowing.
I would likely use it if the mirror view was blocked by things in the vehicle.
This is our 3rd vehicle with camera rearview -- only have it because it's part of a package that had to be added to get other things I wanted.
I do like the Auto-dimming feature. Camera mirror is auto dimming when camera is off.
Auto-dimming has spoiled me -- I'd prefer not to go back to a manual dimming.
As I write this I'm wondering if the auto-dimming in camera mode is not working on yours.
Presumably dealer service has a diagnostic procedure to test that function.
Mine works pretty good but in foggy conditions does odd things like shown above.  I still like it better than no camera as the normal mirror does not have great view with rear headrest.
I don't like the mirror camera, I only use it when bed cover is fully up blocking the window with a tall load.
I keep the rear headrests folded down when back seat is unoccupied.
Don’t have enough time to write a long post but long story short: I brought it to another dealership since it’s still under factory warranty (Greater Lowell GMC). They looked at it and it only took them 1 second to see something was wrong, service advisor literally said, “yeah that’s not right,” after seeing the image on my rear view mirror.  I was like “THANK YOU!!!” Finally someone believing me without me having to argue my case. Explained everything that happened at Tulley GMC and they said they’ll take care of it. 4 days later I got the call to pickup. they said they changed the camera in the third brake light and that resolved it. Back to normal.
They explained, it only took them longer than usual bc I originally told them Tulley only changed the camera in the third brake light and refused to do anything else (saying the image on the mirror was normal). So Greater Lowell was left with figuring out what else was wrong, turns out after following a troubleshooting flowchart of camera issues and changing/testing everything else of the system, the only thing they didn’t change was the camera I told them Tulley had already did. Turns out that was the culprit. Camera in third brake light malfunctioned. Once they installed a new one, it was perfect image.
the kicker: they did a search of all the work done on my truck and did not see them (Tulley) replacing my camera. They said they found a work order with a camera install, but the part number was not for the camera in the third brake light.
next step is to deal with the service dept at Tulley.
Before and after pics below for reference for one else having the issue:
IMG_3248.thumb.jpeg.0658d5c08a5588c773bd669be3c81cb1.jpegbeforeIMG_3437.thumb.jpeg.fe6003e12b4fd80859965d27bf20e074.jpegafter
Le fait que nos clients veuillent un jeu avec un niveau de risque minimal qui ne les oblige pas à perdre tout leur argent est quelque chose que nous comprenons bien chez Lucky31 Casino. En conséquence, nous offrons la possibilité de faire des dépôts https://lucky31casino.bcz.com/2024/10/28/les-meilleur-lucky31-casino-en-ligne-pour-en-france// d'un euro pour chacune de nos machines à sous et jeux. Il y a un certain nombre d'avantages qui sont associés à ce type de dépôt, y compris les suivants: il n'y a pas de montant significatif qui est mis en danger; il est possible de faire de nombreux dépôts afin de maximiser le temps passé à jouer; et enfin, il est possible d'accéder à des incitations uniques qui ne sont accessibles qu'avec des dépôts modestes.
    blueskytruc
    blueskytruc
  • Who's Online   2 Members, 0 Anonymous, 551 Guests (See full list)
