hello.  2011 Silverado, 5.3L Crew Cab.  In the next few weeks i am going to have a frame shop here locally repair a rust out on my frame.  they are telling me that most likely the support rail over the gas tank may need replacing.  they recommend replacing it for good measure and while the tank is dropped, replace fuel pump.  I tend to agree.
can anyone tell me if this is the correct frame rail support that goes over top the gas tank?
Amazon.com: Dorman 999-965 Rear Front Fuel Tank Crossmember Compatible with Select Chevrolet/GMC Models (OE FIX) : Automotive
thank you
Edited by Bleepster
I would take the bed off to do the crossmembers, easier than dropping the tank and everything is exposed.
thank you
Always check with the manufacturer - Frame Crossmember | 999-965 | Front Fuel Tank Crossmember | Dorman Products
Fits regular, extended and crew.  That member is at the mid way point or forward mid way of the tank.  Front tank strap attaches to it.
Edited by newdude
    DLZ
    DLZ
  • Who's Online   2 Members, 0 Anonymous, 570 Guests (See full list)
