Since buying new 5 years ago, I periodically discover these little paint chips (not on the front of my truck but on the sides… i currently only have 35k miles and it’s a 2020 LTZ. I always hand wash and take great care of it so I have no clue how I keep getting these chips. Wondering if it is just the paint or if anyone had any ideas
Something hit them. Weed eater slinging small pebbles or something, lawn mower, BB gun etc. I can see the divot. The chip is from out to in nothing with the paint from in to out.
Yes travel on gravel roads can easily cause such chip damage to paint as CamGTP suggests.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
