Does anyone know if any of the body or side mirror cameras use the same type of wire connection as the accessory trailer camera?
I found out the grille camera is way different so before I take any more of the truck apart, I thought I would ask.
I checked continuity of the trailer camera harness and it has proper continuity so I want to plug the trailer camera into a similar plug on the truck and see if the camera has puked before I spend money on a replacement.
All of the truck cameras use FAKRA connectors. The trailer camera connection is different, but I don’t know what that connector type is called.
Digging into this further, the trailer accessory camera replacement PN shows that it is used in both side mirrors and the rear view camera in the tailgate.  I accessed the camera in the tailgate and it does use the same connection as the trailer camera.  A quick substitution of cameras and the trailer camera I have works fine.  So now, I'm left with either the trailer harness is broken or something with the trailer app in the infotainment center.  I'm thinking the harness is intermittently opening up.  Does any GM parts guys know if the trailer camera harness is available as a separate PN?
Ă—
Ă—
