Hey, 2011 Silverado 6.2L with 6L80, RWD.
It started late march when I suddenly noticed harsh shifts from 1st to 2nd, even in the morning on a cold engine. The transmission fluid was changed in March 2024, so it was fresh.
  • In normal driving: strong jolt through the body.
  • If I add about 15% throttle: no jolt, but feels like slipping and a slow shift.
  • Flooring it: shifts perfectly.
1) I reset the adaptation using my scanner.
It got better: now it only happens when the fluid is warm, around 32°C (90°F) per the gauge, so no issues when cold.
  • In normal driving: noticeable jolt through the body.
  • If I add about 15% throttle: shifts fine, not like before.
2) Took it to a local GM center.
The transmission tech drived it and said it’s a common 6L80 issue. He suggested starting with the valve body. He swapped in two used valve bodies, but the issue persisted. He reset adaptation each time, drove it, then tested my valve body with a vacuum test, checked seals, etc., and reinstalled it. He didn’t check the channels since the used valve bodies made no difference. My fluid was clean, magnets looked fine. Ended up paying for labor with no fix. That day, it was still shifting harshly, same as before. When I picked it up, I drove in all modes, especially flooring it in S mode.
3) The next day, the jolts were gone.
I think some special service adaptation kicked in. Drove without issues for 2 days. But now I noticed harsh shifting from 2nd to 3rd. It’s a paradox.
4) Decided to change the fluid and filter.
They used a machine to flush and fill 12 liters of AcDelco Dexron VI, in addition I added BG ATC Transmission Conditioner, which is supposed to help with harsh shifts. After a couple of miles, the issue came back: harsh jolt from 1st to 2nd in normal driving, but fine when adding throttle.
The shop now suggests replacing the clutches, piston, and all parts labeled for 2-6.
They didn’t check the TCM. The tech said it’s impossible to test, but as far as he could see via the scanner, there were no error codes or other issues.
Could you please your thoughts and where to search next ?
On my 4L80 a bad input turbine speed sensor caused that problem but it showed as a code, possibly it's still functioning enough that it hasn't thrown a code
    • Part is $233.87.     Not sure where $900 came from?
    • Looks like you have it figured out. Did you run a sensor into the rear diff housing?    What sort of diff temp swings would you see towing or not? I have wondered how hot it can get
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
