Hello I have a 2020 Chevrolet Silverado 1500 LT 8 speed rear wheel drive.I looked on the GM website for a transmission filter but it is showing 2 different versions.Which 1 should I buy?
Only one fits it.  24295812.
2 hours ago, 20CHEVYRIDER said:
So I just ordered a Filter from Rockauto GM GENUINE 24295812.
Is this the correct filter?
It says
 OEM / Interchange Numbers: 24268875, TF922
Use your VIN on the GM parts site!!!!!!!!!!!!!!!!!!!!!!
The 24295812 supersedes to a newer number, 24274402.
As for the pan gasket, it is reusable unless its damaged or leaking.  Just wipe it with a lint free cloth and reuse it.  I did on mine, no leaks.
What you need to do on the GM parts site is use your VIN.  If I use a VIN for a 5.3 and 8 speed 2020 it only comes up with one filter applicable, the 24274402 which should be the superseding # to 24295812.  Not all 3 filters without the VIN.  Everyone always wonders or complains when a dealer wants the VIN to look up parts, and this is a prime example.  It will narrow down to applicable items quicker.
Edited by newdude
  • Haha 1
