20CHEVYRIDER Posted June 10, 2025 Posted June 10, 2025 Hello I have a 2020 Chevrolet Silverado 1500 LT 8 speed rear wheel drive.I looked on the GM website for a transmission filter but it is showing 2 different versions.Which 1 should I buy?
newdude Posted June 10, 2025 Posted June 10, 2025 1 hour ago, 20CHEVYRIDER said: Hello I have a 2020 Chevrolet Silverado 1500 LT 8 speed rear wheel drive.I looked on the GM website for a transmission filter but it is showing 2 different versions.Which 1 should I buy? Only one fits it. 24295812.
20CHEVYRIDER Posted June 10, 2025 Author Posted June 10, 2025 Does anyone know a good place that I can order the gasket and filter ? I noticed on the GM website they are out of stock for the filter.
20CHEVYRIDER Posted June 18, 2025 Author Posted June 18, 2025 So I just ordered a Filter from Rockauto GM GENUINE 24295812. Is this the correct filter? It says OEM / Interchange Numbers: 24268875, TF922 1
newdude Posted June 18, 2025 Posted June 18, 2025 (edited) 2 hours ago, 20CHEVYRIDER said: So I just ordered a Filter from Rockauto GM GENUINE 24295812. Is this the correct filter? It says OEM / Interchange Numbers: 24268875, TF922 Use your VIN on the GM parts site!!!!!!!!!!!!!!!!!!!!!! The 24295812 supersedes to a newer number, 24274402. As for the pan gasket, it is reusable unless its damaged or leaking. Just wipe it with a lint free cloth and reuse it. I did on mine, no leaks. What you need to do on the GM parts site is use your VIN. If I use a VIN for a 5.3 and 8 speed 2020 it only comes up with one filter applicable, the 24274402 which should be the superseding # to 24295812. Not all 3 filters without the VIN. Everyone always wonders or complains when a dealer wants the VIN to look up parts, and this is a prime example. It will narrow down to applicable items quicker. Edited June 18, 2025 by newdude 1
Register a new accountSign in
