Yes, this is definitely being nitpicking… but want to just ask if anyone else noticed this. When a phone call starts over Apple CarPlay, it lowers the climate control fan speed, but on every other vehicle I’ve driven (I travel for work so trust me I’ve driven a lot of rentals), including all my other GM vehicles, when I’m done with a phone call using Apple CarPlay the fan speed automatically reverts back to what it was previously set to. But this vehicle (2025 HD SLT) I have to continuously put the fan speed back manually once the phone call has ended.
I assume this is a programming error that can be fixed via over the air update.
Edited by EXSlider400
What model of phone? I know the older iphones had this issue (the ones that just started to use carplay). When I upgraded to a iphone 15 that issue stopped. I've never seen it be a truck issue, more so a phone issue.
I’ve had the same phone for about four years and it is an iPhone 11 I think but either way it only does it in my new truck, when I travel for work it works in all the rental vehicles, and this same phone worked fine in my old 2019 sierra. I had not updated it since it worked in my old vehicle so nothing had changed, but I did update it tonight to the new iOS, but it still doesn’t work. Tried it with my wife’s phone as she has a brand new iPhone and it still doesn’t make the fan speed go back to normal after a call either. Appreciate the good idea though.
My 25 did this when I got it. One of the updates that was pushed to the truck fixed it about a month ago. Maybe check to see if yours is up to date.
My 24 does this sometimes. Not too often though. Sometimes the audio returns to only the front left speaker as well.
That one had me hopeful but dang no luck. IMG_0517.thumb.jpeg.ed0faa59fced44030906c00ec7c295f9.jpegIMG_0518.thumb.jpeg.af949085419c6f7f38d0405743f4df6b.jpeg
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
