Cant seem to find fuse that controls the AGS on my 2018 5.3 It doesnt seem to be listed on the fuse panel top. Any help would be appreciated.
Fuse 47 in engine bay
Watch video at the 3min 50 sec time
Owners manual list's fuse #47 for the throttle body? Wonder why they list the fuse for the areoshutters in the 14-15, but not for the 16-18?
Edited by JimCost2014
This was discussed in 2022 here:
And to add to @rav3's post, there is this ( @JimCost2014 fuse 47 mentioned again, interesting):
Edited by MikeBMW
