Anyone know how many 10L1000 are on the road ? Let say since 2022 Are those numbers available somewhere ?
2020 was I believe the first year for them behind the Duramax and as you may know a lot of the HD trucks GM builds are Duramax as the gas version takes second fiddle and by a long shot at some dealerships. 2024 being the first year for that "similar" 10L1000 trans for the gas and here we are with 2026 models having been out for a few months now. That should add up to one whack of 10 speed Allision branded transmissions out there.
A grain of salt is always the best way too go with the internet. I had a f150 2014 and despite what one can read on the internet, my phasers and chain never failed, nor the turbos
  • Haha 1
I am not sure how many km you had on your truck but a mechanic that runs his own shop in town gets all sorts of Ford 5 and 3.5 engine trucks falling into his lap and often as a last ditch effort to somehow magically repair the mess because in some cases its already just been to the dealer where they spent many thousands on doing a timing chain job and for "some reason" things are still not working right and I believe its come down often to one factor, they simply did not change the engine oil often enough for the type of use they were giving their truck and ruined their engine as he figures out that the bottom end is shot on the engine that they had all this recent prior work done on.
8 hours ago, Silverado4x4 said:
Not going to hurt their sales at all. I bet 98% of the people who buy these trucks with the Allison don't even know what an Allison transmission is.
Well I knew, but then I had been following the 10 speed rumors in the gas model HD for several years and pulled the trigger in 2024. This has been around the internet for a while but…
When we were camping last January the family’s tow vehicle next to us was a Chevy 2500HD. We commented on each others choice of vehicles and the biggest selling point for the guy was in fact the “ Allison transmission”. I didn’t try and correct him but I’m inclined to think the percentage, while maybe not 98%, is still rather high.
Low mileage at 125,000 km, but 90% of that was pulling my travel trailer weighing close to 8,000 lbs. I didn’t baby it either. That truck was maxed out in every corners but never above the spec sheet. Oil changes were once a year or whenever the OLM indicator signaled. It rattled only once, three years ago—maybe just a coincidence? At the time, I had installed a FRAM Ultra, the first time I didn’t use an OEM filter. I immediately replaced the filter, and it never rattled again. Coincidence?
You will never know but eventually those engines do have turbo failures ( certainly have heard of that around here with past 3.5 owners when the truck was still on warranty ) and valve train or should say valve drive train issues as that long long chain wears and sooner or later becomes an item that needs replacing and its a very expensive process to have a shop replace it. You got a lot of heavy towing use out of it, count yourself lucky and hope that your new truck does as well as it did. And your new truck is without a doubt or at least in my mind the more capable unit due to its weight in a bad weather/wind situation.
I think the 98% is accurate if you're describing people who think they actually have an Allison transmission. Most people don't research everything to death on the internet and probably think if a manufacturer says "Allison transmission" then it's an Allison transmission rather than "hey, I better go research this to make sure it's actually an Allison".
Edited by BuckWallace
One of the Duramax forums used to have an Allison engineer on there (aprox. 10 yrs back) and he had lots of info. But as always happens, keyboard experts (in their own minds) drove him away and he never came back.
Edited by Z45
The new truck is a complete game-changer compared to the old one, much better in every aspect. The only slight disappointment is the engine power. Yes, the truck is heavier and all that, but the little 3.5, in terms of power alone, can hold its own against the 6.6. Not talking about long-term longevity or reliability, just pure power for power. I love my new truck and I have no regrets
N242454440 recall which was the 2020-2022 reprogram the TCM to detect valve body failure.
Per that recall, it covered 461,839 total trucks (LD and HD with 10 speed and diesel) for 2020-2022 model years.
HD specific, that was 166,541 Silverado HD and 135,323 Sierra HD.  So just for those three model years, 2020, 2021 and until January 11, 2022 (past that date they have the updated software) they produced 301,864 Duramax 10L1000 powered HD trucks.
Edited by newdude
    Paul8556
    Paul8556
  • Who's Online   5 Members, 0 Anonymous, 596 Guests (See full list)
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
