For those who have the GM trailer TPMS installed in a trailer and the tires/wheels are more than 25' away from the license plate (where the sensor receiver is at), here is a simple modification to make your sensors rear correctly and not give you the "Check Trailer TPMS" warning. This should work on any 2020+ truck.
My trailer has a 40' deck, not counting the gooseneck. The truck would hit or miss connecting to the TPMS in the trailer tires.
Here is the parts list:
OEM style connectors
https://www.amazon.com/dp/B0C3VY14MG?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
3 Pin connector
https://www.amazon.com/dp/B0BGQ28631?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_42
18 AWG wiring (3 conductor)
https://www.amazon.com/dp/B09YDMGL2M?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_4&th=1
Remove the license plate and pop the sensor off the bracket and unplug it. I fished about 5' of the wire down through the rubber plug down to the location where the receiver is mounted. Build a female end pin out with the OEM style connectors and plug it into the factory wiring harness. On the end that runs down from the rubber plug in the bed, put one of the 3 pin plugs on the end of the wire. I used these connectors here since they are easier to disconnect by hand.
Now run your wire on your trailer. I started at the 7-pin plug and ran it back to where I was mounting the GM receiver. I followed the GM rear trailer camera wiring. Now build a male OE style plug on the end of the wire. Mount the receiver and plug it in.
**Make sure when you plug in your trailer to the truck, the receiver gets plugged FIRST then the 7-pin plug. When unplugging, the 7-pin FIRST and the receiver last. Plugging in the 7-pin triggers the truck to activate the receiver.
Finally, plug everything in and test the system. I went through the steps to relearn the trailer TPMS. I knew instantly that it worked because of how fast the truck picked them up.
1 minute ago, carkhz316 said:
So you moved the trailer TPMS module to the trailer, correct?
That is correct. The truck only activates the module when it detects something plugged into the 7-pin plug. That is why the module has to be plugged in before the 7-pin.
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
