Has anyone seen or tried this unit?
https://idoing2006.com/products/idoing-12-95inch-android-radio-head-unit-for-chery-chevrolet-silverado-gmc-sierra-2019-2023?variant=42333333487714
  I like it more than the 14" displays.  I'm also very interested in the Stinger Horizon 12 kit, but it says its not Bose compatible.
https://www.ceoutlook.com/2025/11/04/stinger-shows-horizon12-for-late-model-gm-trucks/
Im most worried about camera integration on my LTZ.  I have the max trailer package so my 360 view is really 270 deg. The front is missing For trailer through-view add on option.   But also have the low speed front tire view which is very awesome.  And secondary tailgate cam for trailer ball downward view.   Not sure if these will all work on any unit.
  • 4 weeks later...
So i contacted both the distributor and manufacturer.  It still doesnt totally make sense.  Apparently this is just "screen replacement" that uses factory radio.  But...it has power outputs and a toslink out.  And an EQ.  So that makes no sense for a factory radio.
I get the sense that there is more to it than either party cares to explain.
The Linkswell looks far superior to anything else on the market.  But, its a lot more expensive and requires a $400 adapter if you have a Bose system.
None of them retain XM, but all allow you to use the XM app via wireless.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
