Hello, I have a 2018 Silverado 2500 Duramax. The brakes are causing a vibration when applied. The pedal is not pulsing. I can only assume the rotors are warped. This has happened on several 2500s I’ve owned. It does have 100,000 miles. The pads look decent yet. So I’m satisfied with that. Should I stick with OEM and if so which ones? I believe they offer 3. Or is there a superior aftermarket product? TIA
If the pedal isn't pulsing, it's likely the rear rotors.
OEM is fine but you may pay for it being OEM. I've never had a problem with the Ultra Premium/Adaptive One rotors from Napa. They are really good rotors in my opinion. You can save yourself money by ordering them online and picking up in store as well, they have discounts on the website when doing that.
