IMG_0475.thumb.jpeg.552bcf7b0d6b45baae82646755e50580.jpegIMG_0473.thumb.jpeg.d436193a8d24361b8c622dcf284005f6.jpegYes I bought the one and only tuner for our L8T trucks, unlocked the ECM/ PCM loaded up the ridiculous 93 octane tune and had at it for your enjoyment 😂.
zero to sixty was a 6.87 as well
21 Sierra 2500 CC HD 6L90,  leveled and 35” Toyo open country MT, full 36 gallons of fuel , driver / passenger and about 150 pounds of tools and accessories under the seat
I must say very snappy for a heavy gas truck. I’m currently running the 87 tune with firm shifts and it’s great responsiveness for everyday. The 93 tune power boost is significant they claim 28 hp and 50 lbs ft torque I believe that 💯. The 87/89 tunes are just a small power increase but really wake up the throttle and improve transmission shifts.
Anyway posting for your enjoyment
Edited by Shatterz
That's running with IROCs and 5.0s of the late 80s which in context is pretty impressive for a giant heavy brick.
2 hours ago, newdude said:
So where's the pre data?  Before the DiabloSport to show the "improvement"?
I’ll admit it’s been awhile. I’ve experienced at least 6 hand held tuners. During that time I could adjust shift points, RPM limits, advance timing to use high octane fuel and later adjust for E-85. All claimed up to 30 HP gains or more. That along with cold air and tuned exhaust. Made the driving experience way more enjoyable. Especially merging on to freeways. Yahoo. Did the numbers actually bare that out? Who cares it felt like it. Why else would they now put different modes to choose from even in trucks? They even add sounds to electric vehicles. With force induction there’s no doubt. I know been there. To ask means you just don’t get it.
well if I didn’t just break my arm and now can’t drive for a while I’d do another tune/ no tune comparison 😄
fyi I did a  0-60 stock  oem wheels and tires with obd mx link before my much heavier  load range F Toyo mud terrain 35s and it was 7.36, so that gives you a sense of marked improvement. I think 6.5 seconds is easily achieved with stock tire size / no passengers or extra weight of things in the truck.
Im not trying to win any drag race but it’s interesting what these trucks and engine  can achieve given the weight of these trucks.
the L8T savanna or express vans with a tune would be downright quick lol
Edited by Shatterz
Or a 30yr old Buick station wagon.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,284 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
