This past Saturday I had the a/c line replaced that goes to the firewall its the line for low & high side. Anyway we vacuumed it down and then made a mistake and put 3.0lb in instead of 2.7lb this has front & rear a/c. My issue is the a/c works great if you are sitting still but once you're driving it doesn't stay cold. I know the system is slightly over filled and would assume that might have something to do with it any help would be appreciated. thanks
Possibly the under hood temperature is lowering when traveling down the road allowing it to freeze up. Pressure switch should cut if off first...
