Hey guys,
I’ve got a 2024 Silverado 1500 and I’m trying to get ahead of maintenance on the diffs, but I’m running into a lot of mixed info.
Truck setup:
  • Rear: GM SU8 w/ G80 locker, 3.23 gears
  • Front: AAM SU4
What I’m confused about:
  1. Gear oil – does it really matter if I stick with ACDelco OEM?
    I’m seeing the recommended ACDelco fluid isn’t very easy to find (especially for the rear).
    • Are there solid alternatives (amsoil, Valvoline, etc.) that meet spec?
    • If so, what is that spec other than just 75w85
  2. Where are you guys actually buying the OEM fluid?
    I’m not seeing much availability online (Amazon, etc.), so wondering if dealer is basically the only option.
  3. Gaskets:
    • I’ve read the front diff doesn’t use/need a replaceable gasket
    • Does the rear diff cover need a new gasket, or is it RTV from the factory?
  4. Service intervals:
    For relatively mild use (some towing/hauling, nothing extreme), what intervals are you guys actually running for the front and rear diffs?
  5. Where are you getting official info? Is everyone just using the GM service manual / SI subscription, or is there another reliable source I’m missing?
Appreciate any insight
No any fluid will work, just put in what the manual says, 75w85 or 75w90 (it'll vary for whatever reason).  Lots will say they include limited slip diff additives.  They are fine, just don't add any other additive to the rear diff for the G80.
I buy a good synethetic oil and it's good to go.
I would look at the diff, you can tell if it's got a gasket or sealant.  You can also check for drain plugs, front diff might have one, rear isn't likely to.  Also look to see how much room there is around the fill port for the diff.  My diff's have enough space, so I can use 1qt bottles, tilt them mostly upside down and squirt directly into the diff, w less clearance, getting fluid that's in a bag makes it easier to do, or you can get a manual pump to get it into the diff.
The diff's are pretty reliable, so I would do it sooner than the regular interval but longer than the extreme service one.
I recommend a subscription to it at alldata.com.  They are running a special right now, up to 30% off their subscriptions.
2.  www.rockauto.com
4.  Iirc, you only need to service the differentials if you have a leak.  There is no service interval listed in the manual.
5.  Owners manual, which I access through the MyChevrolet app.
When I had the front and rear diffs serviced I used Amsoil Severe Gear 75W-80 synthetic gear lube.
my 21 Sierra has SU4 front, SU7 rear.
  • 1 month later...
I have a 2022 Silverado with the same setup as the OP (SU4 front, SU8 rear).  Part numbers are Canadian.
After considerable research and lots of youtube:
1. SU8 gasket is reusable.  GM part number 84412728.  The SU8 requires AC Delco 75W-85 GL-4 fluid, GM part number 19368514.
2. SU4 gasket is one-time.  GM part number 84428297.  The SU4 requires ACDelco High Efficiency Gear Oil 75W-85 GL-5 fluid, GM part number 19300457.
Edit:  The picture of GM part number 19368514 shows GL-5 on the label, not GL-4.  So I did more research.  It seems the "SU8" is irrelevant for fluid purposes.  What is relevant is if you have the G80 locking differential.  I do have this one and the problem is it has brass and copper mechanisms.  The sulfur-based additives in GL-5 will react with those metals so you need GL-5 gear oil with "non-reactive, buffered sulfur-phosphorus additives".  Apparently a degree in chemical engineering would also be useful.
Amsoil Severe Gear and some others use those 'non-reactive' extreme pressure additives and that is why they are compatible with the G80/SU8 combination.
Also FYI:  the transfer case uses Dexron VI synthetic automatic transmission fluid GM part number 88865549, but you can get any Dexron VI from Mobil/Valvoline/Amsoil.
And in case you have it, the 8L90 MQE transmission (8-speed) uses Mobil 1 Synthetic LV ATF (blue label).  Which is equivalent to Dexron HP.  Hope this helps.
Edited by 22SLT
Additional information added.
    • My centre console USB ports haven’t been working and the one in the glovebox is starting to act up. When I plug my phone into the cord the radio will go black and stop playing, and the CarPlay is inconsistent.   I checked the fuses and they were fine. I changed the USB port out and still nothing. Hoping for some advice on what I should be looking at.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
    • The average lifespan of automobiles on the road is increasing - here's why
    • Typically it is the Torque Converter, I have a 2.7L Trail Boss and between 25-65 MPH at 1300-1500 rpms under light throttle it has a shudder which I almost consider and bobble or a gargle sound. They replaced my TC but it did not help any, others say it has fixed their issues. It has been back twice now with no fix after.
