Ive been a chevy man for 55+ years now and I'm probably on my last truck.
i bought a 2021 Silverado new with the 2.7 turbo. great truck and i like the 4 banger, a lot of power, surprising.
Ive read that 200,000 miles is the lifespan and im hoping thats BS.
i also have read the newer v8 engines are having issues like blown engines, top end frailer
im wondering if anyone has heard of a 2.7 with more than 200,000 on it
I haven’t heard of any with that kind of mileage yet. I’ve heard of several with over 100k miles with no problems. Looking forward to others chiming in.
Changing the oil more often and or using better quality oil would be my mode of operation.
I think anyone who sees 200k in any modern day truck today is doing good.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 1,404 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
