I'm not sure if there are any threads on this so here goes !
You fellas that have a 2024 Chevrolet 2500 HD with 6.6 Gas engine what size Travel Trailer are you towing ?
We are thinking a bumper pull not 5th wheel
What is the dry weight of the trailer you are hauling ? What does it weigh after you load it up with full propane tanks ,water  and all the gear you have in the trailer
I don't want to purchase a trailer that is too heavy and the the truck struggles
Is there a recommended safe factor as in how much you should load your trailer up with additional weight beyond the dry weight ?
I'm a bit naive to all the GVW and appropriate nomenclature aspects to Gross Weight    Gross Combined  Weight   Payload etc
Thank you
Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least.
My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing.
Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit.
You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling.
Marv
With the gasser you're pretty much good to go with any travel trailer 10k or less GVWR. You'll be hard-pressed to find something that size that'll put you over payload. Even over that you're gonna be fine with most bumper pulls, but pay attention to tongue/pin weight. Depending on how far and often you tow you might be getting into diesel territory as far as how pleasant of a towing experience you want.
Happy 250th, 4th of July-
We have a 2024 gmc 2500hd sle doublecab 6.6l gas 4x4, 3540 payload, towing a 2015 Rockwood 8329 TT, 35' with tractor supply box on back.
Dry weight is 7200, but the important number you need to always use is the 9000 GVWR.
It tows it just fine, that 6.6l gas engine is a work horse, Later-
thanks Fellas
I really need to familiarize myself with all the Abbreviations to know what each one means
Buck If I'm correct GVWR does not include the trailers weight ,dry or all things in it water propane ,items you put into it ?
So is it possible that I could be over on one limit and under on another ?
Sorry I'm just shooting things off the top of my head !
Edited by BCGM
The trailer's GVWR would be the max "loaded" weight rating of the trailer, so dry weight plus propane, gear, water, etc.
Thank you
Really depends on what extent the towing is.  Are you going across the country on highways or to fairly local campgrounds?  If you're just local towing then I wouldn't derate your truck much, just make sure the weight of your trailer and equipment stays below your limit.  Which for my truck is 14500lbs bumper pull.  Yeah it will work hard when you're over 5 figures in weight but who cares if it is just say 50 miles.
In my opinion the main thing with towing campers is wind resistance.  My 3200lb single axle camper tows fairly hard for what it is due to the wind.  But then if I use my truck to tow a family members 8000lb camper it doesn't really feel any different as wind resistance is similar. I've also towed a 5000lb airstream and it barely felt like anything was there.
My truck is a 2024 2500 LT crew cab with the 6.6 gas engine and 10 speed trans.  It has a payload of 3578 lbs.  We pull a 22' Grand Design 17MKE that has dry weight of 5006 lbs. and a gross weight of 6395 lbs.  The trailer weighs about 5800 lbs. when loaded up with all the gear.  I don't fill the water tank for travel as most of our trips are to state parks that are within a day's drive.  Depending on the wind I get anywhere from 7.5 to 9 mpg.  I do use a weight distribution hitch (WDH) and have no problems with sway or being pulled/pushed side to side by 18-wheelers passing by me.  The trailer is about the same length of the truck so that helps a lot.  I say that because we traded in our 33' Grand Design 2670 MK (7800 lbs. loaded with gear) and using the same WDH, it would get pulled side to side by big trucks passing by me. It was not bad, but you needed to stay alert and know when a big truck was pulling up beside you.  I got about 7 to 8 mpg pulling that trailer.  I normally drive about 65 to 67 mph when pulling.  Overall, I love the payload capability of the truck as I doubt I will ever get close to its limit and I love the stability it offers over a half ton truck while pulling a trailer.  I have just over 30000 miles on the truck and have not had any issues.  We live in Texas where it is relatively flat, just windy.
    • Is this the pan everyone is talking about PPE Power 128051910 . this can be gotten from JEGS.
    • My truck is a 2024 2500 LT crew cab with the 6.6 gas engine and 10 speed trans.  It has a payload of 3578 lbs.  We pull a 22' Grand Design 17MKE that has dry weight of 5006 lbs. and a gross weight of 6395 lbs.  The trailer weighs about 5800 lbs. when loaded up with all the gear.  I don't fill the water tank for travel as most of our trips are to state parks that are within a day's drive.  Depending on the wind I get anywhere from 7.5 to 9 mpg.  I do use a weight distribution hitch (WDH) and have no problems with sway or being pulled/pushed side to side by 18-wheelers passing by me.  The trailer is about the same length of the truck so that helps a lot.  I say that because we traded in our 33' Grand Design 2670 MK (7800 lbs. loaded with gear) and using the same WDH, it would get pulled side to side by big trucks passing by me. It was not bad, but you needed to stay alert and know when a big truck was pulling up beside you.  I got about 7 to 8 mpg pulling that trailer.  I normally drive about 65 to 67 mph when pulling.  Overall, I love the payload capability of the truck as I doubt I will ever get close to its limit and I love the stability it offers over a half ton truck while pulling a trailer.  I have just over 30000 miles on the truck and have not had any issues.  We live in Texas where it is relatively flat, just windy.
    • I will say though that the 5.00 a gallon for only one fuel stop while on the Number 1, that privilege of driving from the point of Paso Robles ( where I fueled up before crossing to the coast ) and all the way up ... across the Golden Gate where I stopped and walked on the bridge ( and someone jumped off the bridge opposite the side I was on ... never saw it happen but the tow truck/paramedic told me ) and continued on north back onto No 1 and all the way up to where it connects to 101 and also explored some of the Red Woods although had been through some of that before. The fantastic view of that scenic ocean route was most certainly worth the extra dollars I spent on fuel. Just prior to that I had driven through Death Valley and that was some experience in the middle of July, then spent a couple of days in Yosemite and hiked to the top of Half Dome. The summer of 2007 was very memorable for what I saw and experienced in California.
    • Really depends on what extent the towing is.  Are you going across the country on highways or to fairly local campgrounds?  If you're just local towing then I wouldn't derate your truck much, just make sure the weight of your trailer and equipment stays below your limit.  Which for my truck is 14500lbs bumper pull.  Yeah it will work hard when you're over 5 figures in weight but who cares if it is just say 50 miles.    In my opinion the main thing with towing campers is wind resistance.  My 3200lb single axle camper tows fairly hard for what it is due to the wind.  But then if I use my truck to tow a family members 8000lb camper it doesn't really feel any different as wind resistance is similar. I've also towed a 5000lb airstream and it barely felt like anything was there.
    • I think the excitement has run its course. Or, probably need a break from the truck for a few days.   Win some, lose some, again. There was still a coolant weep from the front of the engine. This time it was one of those worm-drive hose clamps on the upper hose connecting to the water neck. There's a reason the factory doesn't use those type of clamps; they suck. The hose is all distorted and flared at the end from someone over-tightening it. The water neck just needed to be cleaned, hose seated, and have a *good* hose clamp put on, if the hose wasn't so mangled.   Thought I'd kill two birds with one stone and try to diagnose the EGR issue. It's likely a failed EGR but before I spent $85 on the part I wanted to make sure ports weren't clogged or the pintle wasn't stuck. It was kind of a bugger to remove with the upper intake installed. Re-install (because I wanted to drive it) proved more difficult.   Per the stack of service paperwork, the EGR has already been replaced 4 times since 1996.   It would reason, then, that the EGR flange on the lower intake manifold has had its share of techs trying to work quickly and maybe one of them seated a bolt slightly cross-threaded at one time. The bolt didn't come out without significant effort and tried as I did, it wouldn't go in without significant effort. And then, the mounting ear on the right side of the EGR (lower intake casting) cracked, and crumbled off. $%&@!!!   I hate everything. Or, at least, I did in that moment. I was pretty calm, considering. This is what older, junky vehicles do. They nickel and dime their owners, piss them off, and things break that shouldn't break because of shoddy design/workmanship, poorly done repairs.   If I want to make it right, I'll need to replace the lower intake manifold and basically re-do everything I spent days doing. At least it should go quicker this time, right?! Looks like a lower intake (used/junk, of course) will run me about $150.   Once I get the new EGR, I'll see if I can bolt it up snug enough to verify proper operation, and if it solves the persistent CEL that sets on decel for EGR flow, I'll know I'm back on the right track. And then I can decide how to proceed.   Also, an idler pulley has given up. It began squeaking in pain on startup. It's clear this truck hasn't been thoroughly driven in a long, long time as things are just letting go and shaking out. I may have given it the beans once or twice to make sure my intake gaskets were doing their job. Flog an old vehicle, expect what it gives in return.
