Fairly new product, just picked up two bottles at Autozone, buy one get one free sale. Also sold at Advance and Walmart so far. The Restore & Protect oil seems to be a legitimate product. Now we will see if this unseats my Redline SI-1 as the go to cleaner. This product is NOT using PEA but some other proprietary chemical. Will be interesting to see some real world results…
4 hours ago, Grumpy Bear said:
Hummm....let me know my little guineapig. They've been on a roll recently, right?
https://contentassets.autozone.com/safety_data_sheet/USA/1580931.pdf
Yeah, they’ve really been hitting it hard with the R&D. If their oil wasn’t performing as well as it has been for people I’d say this just a cash grab/ marketing ploy. But the BITOG folks seem to think this may be legit too.
Trying it in the Jeep, fuel has been a problem in the samples and while I have new injectors on the shelf, this is an easier proposition…
  • Thanks 1
I haven't been able to get on BITOG this week. Thinks I'm a robot and kicks me out. :crackup:They have no idea how right they are. :rollin:
  • Thanks 1
  • Haha 2
  • 4 weeks later...
And, lucky they are?
  • Thanks 1
Well, how did it go?
Can’t really say I noticed any difference during treatment or since. Granted it ran perfectly before anyway so can’t expect much.
My hope is lower fuel in the oil analysis. 🤷🏻‍♂️
BTW, finally got on BITOG. Rebooting my PC gets me in every time. LOL.
    • So, my 2021 only gets radio updates, right? If that's the case, my radio is doing just fine and probably better off without any updates, especially considering the problems I've been reading about after updates were performed.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
