Is this supposed to be bent like this?
Is this bolt in the middle supposed to look like this? I dont recall it looking like this before.
Is the adjustment bolt actually bent,or is the cable just tweaked a little?
It's kinda hard to tell from the picture
Anyhow,it kinda looks like 1 of the rear cables may be a little stretched,or hanging up a bit....
Ryan
your picture shows perfectly what i have posted in the past.
Why do they have the Park Brake "ADJUSTMENT" bolt all the way extended? is it not common sense that a park brake would loosen up after the factory?
thanks :thumbs:
its definitly bent. My only guess is sometime this past winter a large chunk of ice got hung up on there and bent it. I know that area is good for trapping snow and then it freezes if you dont knock it off
Mine looks the exact same way, I don't think this is a problem or even needs to be fixed. It's just a parking brake and when not engaged there is no (or relatively low) pressure on the cables.
Just my opinion though!
Mine looks exactly the same. Never worried about it much - just figured it wasn't the best of engineering. No problems though. :D
As long as its not cracked and still holds the trk when its applied :crackup:
But it does look funny...but than again...how often do you get under thr to look at it? :D
