I'm going to buy some BFG A/T's or M/T's and I want to know how big I can go without having to buy new wheels...
My Blazer has 235's on it right now with a 15" rim.
I don't have a lift and I don't plan on putting one on because of stability issues.
I was wondering if I can fit 31"s on my Blazer without rubbing.
Anyone know?
Thanks.
Well,we really need a little more info first.
Is it 2wd or 4wd?
Stock or aftermarket wheels?
I'm assuming by your name that you take your Blazer off road but if not,please state such.
Going by your name,I'm guessing that you have a non ZR2 Blazer that is 4wd in which case you might be able to get away with a p265 75 R15 depending on how hard you push it off road but if you do get after it you may have some rubbing.
Is it 2wd or 4wd?
Sorry about that.
It's 4wd.
Stock wheels.
I do take it off road.
Unfortunately it is not a ZR2, even though that is what I wanted. So 265's you say...? Hmm, I'm going to check out tire rack and see what they have for that size. Thanks.
Woah, hold on a second, he said 265's if it was a ZR2, since your truck is not you won't have the same amount of clearance as a ZR2.
IMO, if you want to use this truck to do a lot of mudding then your best bet would be to add some type of lift.  I'm not sure on what you mean about stability issues w/ a lift.  The only thing that I can think of is going 80mph around a corner and worrying about rolling w/ the higher center of gravity.
i agree there is no way 265's would fit under a 4wd blazer.  The stock tires are pretty close to rubbing (235's) on my moms blazer.  I honestly dont think you could go much bigger if even bigger at all
That's why I stated you might be able to get away with 265's.I wasn't sure which is why I didn't say that they will work though I'm sure you could probably be close to fitting them with a torsion bar crank or with Superlift control arms and t-bar reindexers.
Jon
I was referring to the 265's on a non Z Blazer.I know the will work on a ZR2 Blazer so that is a moot point.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
    • Thank you. I'll give it a try
    • I just spent the last 45K miles doing samples every oil change over more than a full year to get the data for seasons and break-in to broke in.    I found the same thing to be true. Something was always teetering on done or had stepped off the cliff long before the OLM was DOA. In fact, I found about a thousand mile difference between summer and winter. That is during the winter half the OLM was STILL too long. Even the severe schedule was to long in the winter.   Now having done the work I can say I was NOT DISAPOINTED. I saw nothing I didn't already know. Nothing my father hadn't already demonstrated in his 2K OCI's pushing dated iron on dated oils and weak filters to mileages well beyond 300K.   Building on his work through use of Lab testing it wasn't hard to find the correlation between 'sight/feel/odor, the things dad relied on, and test results. Use of current viscosity stable chemistries & filters has pushed that marker for my motors out to 3K summer, 4K winter.    So the early lies were 3K on conventional oil and the lie upon the lie was 7K+. turns out to be off by a factor of two.    So... it is true that modern chemistry has doubled the useful oil life. But the base milage that came from was off by double. It's how good lies work. Partly true, sometimes mostly true so that your meter isn't set off. It also means that non-shear-stable shelf oils are only now as good as the old oils were in their best case scenario.    So the question now is how do we improve on that? Thus the question into cleanliness among the other items listed in the post quoted below.    If this bores you, feel free not to participate.
    • Is it though?  Like LTZ, not a high take rate.  Current Sierra has AT4, Denali and Elevation as its main bread winners.  Each trim accounting for 25-35% of sales for Sierra.  SLT makes up about 10-15% at best.        Like others have predicted here for GMC, it will be:   - Pro (equal to WT Chevy)   - Elevation (replaces SLE and SLT)   - AT4 (and X)   - Denali (and Ultimate).
