87 blazer electrical problem
I have a 1987 Chevy Blazer, 350 TBI. last night i had to run to the store, when i started the truck, it suddenly acted like the battery was weak. i thought to myself, strange were did that come from. has been starting fine. went 3 blks and parked it at the store. was in there no more then 5 mins. went to start the truck, and nothing, not even a click. all the accessories, lights stereo all work fine. nothing looks dim. anybody have any ideas? would appreciate it. i'm right in the middle of job hunting, i need to get this thing back on the road.
A hot engine can actually require more starting power than a cold one sometimes. I discovered this 30 years ago with a big block car a had at the time (a Impala SS 396). It one day became hard to start hot and fine cold. I fussed with it for a week before I slapped in a new strong battery and the problem went anyway and never came back for the last few years I had the car.
Could be bad battery cables...or even a bad starter...if the starter bushings r worn the HOT NO CRANK could be caused by the armature expanding and rubbing on the stator cause the bushings r worn....or a bad solonoid would do the same thing and loose contact when hot...have the batt. checked..AutoZone or Advance Auto parts do it for free here in my neck of the woods
I would start with the positive battery cable. Don't be fooled by it's good looks :thumbs: It can be fine on the outside, and rotten all the way through.
My 92 was like this, and I've seen quite a few others do the same.
By the time I figured it out, I had to replace the battery. The cable had actually become rotten to the point that it had intermittant contact with the starter, and when I went to replace it, it actually broke, and fell off of the starter.
Hope that helped. :rolleyes:
If the battery is a few year old or older, start with it first, This is not a cable problem as it would be present cold too and if it was it would be less likely when hot as metal expands when hot and tightens a loss connection and it would show up more cold. This is a battery thing most likely. It could be starter too but I would swap battery before I started pulling parts.
