Foglight beam height
Ok, I got the burned out bulbs replaced, but not without messing up the height adjustment...I thought that was a screw to remove the bulb. Dummy I am. So they are about even (I need to find a wall and line them up), but what height should I set them to? Just below the lowbeams at 20' away from the wall or something like that, or does someone know the actual setting from the factory?
This is on a 2002 Tahoe Z71, with a stock suspension/tires (factory height).
Thanks
Thanks
I'd measure where mine are but I screwed em up too (off road) :tear:
Well since know one else seems to know, I will adjust mine so that their hot spot will be right about where the main headlights stop illuminating (closest to the truck).
Hmmm not very clear. The dark spot between the bumper and where the headlights light up the road.
No better...
