Speed limiter
I guess it's not necessary for me....I got a speeding ticket tonight coming back for cleveland boat show......wah!!!
dang this smooth horsepower!!
Where are you at in NE OH...I'm from N. Olmsted.  Who tagged you, Brookpark?
Jet Chips has what they call a SCU - Speed Control Unit.  It removes the top speed limiter and allows you to reprogram the speedo for larger tires.  It's about $169.99 compared to $320+ for a HPP 3.  Hadn't tried it, but its on my wish list -
When I got the Z71 package on my AV, the wheel size was increased from 16 in rims to 17 in rims without any change in the tire size or aspect ratio.  This could change the speed by ~3%.  Did the Chevy change or adjust the chip for the Z71 packages?  If so, can it be changed by others including the top speed limit?
The dealer can adjust for small tire changes - did min from 245/75/16 -> 265/75/16 - about 1/2 service charge ~ $50
I think policy prohibits them from upping the speed limiter - has to be done with an ECM or tranny mod.
BTW - has anyone used the Jet Performance JET SCU 2000?
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
