2000 Z71...Rear Spring Upgrade?
Hi Everyone! This is a great site with great posts! I've been a member for about a month now. I been SEARCHING this site and gathering a BUNCH of information. THANKS!
I own a 2000 1500 series Z71 ext. cab/ short bed truck. I bought this new 2 years ago. Since owning the truck it has been very good transportation. I now own and operate a lawncare business. I really don't have the funds to go out and buy another truck that is more of a truck than a car. I would like to "BEEF" up mine. I would like to increase the PAYLOAD (maybe up it another 700 lbs) and I am planning on changing out the front bars for ones of more substance.
My QUESTION is THIS: has anyone out there "UPGRADED" there rear spring pack to a more HEAVY DUTY pack? If so, could you please pass on some info... :)   Thanks again!
Hi
Welcome to the site glad it has been a help to you
A few options i know of offhand but dont not have experience with
One would be add a leaf or helper springs.
The other would be air bags in the rear.  This is probably a better option
Hopefully someone can shed some info for you
Thanks Ryan!  I'm still not "SOLD" on the AIRBAG set-ups. I'm sure they work, but I think I'm going to go for some add-a-leafs or see if a 2500's  spring pack is a bolt in replacement.
another thing
A delivery guy that i worked with had a 3/4 ton chevy van.  He needed more towing capacity so he took off his stock leaf springs and took them to a truck place that worked with springs.  They rearched them i believe or added a spring to it.  Well whatever they did it had a 1 ton capacity instead of the 3/4 ton.  I thought about having this done but i did other mods in the mean time.
Might also look into that.
You can go ahead and put some 3/4 ton springs on your truck, but it isn't legally going to increase your payload.  Sure you will have heavier duty springs, but what will it matter when your tires, brakes, and the rear axle aren't up to par with the springs.  I think with just wanting up go up an additional 700lbs you will be fairly safe, but at the very least you need to upgrade the tires as well.  Make sure you have atleast a load range "D" tire on there.  If you are not wanting to have a stiffer ride, I would highly recommend going the air bag route.  Going to the 3/4 ton springs (if they will fit) and tougher tires will result in a stiffer ride when unloaded.
Ryan, why are you wanting to go up to a heavier duty spring?  It will probably make the back end of the pickup sit up in the air compared to the front again...
i have thought about the add a leafs.  Rancho has a kit but for the pre 99 trucks which is nice.  Reason i want to increase the payload a little is because summer time i do alot of hauling back and forth to our summer cottage.  We throw a tractor in the back, gear, 3-4 people.  I mean the truck can handle it but i dont know i guess i just want a heavy duty 1/2 ton
Try Hellwig's progressive overloads. I just helped my buddy put a set on his 2000 Chevy 1500. They were 2500lbs overloads. They were easy to put on, less than an hour, you can adjust them to raise your unloaded ride height if you want. They will help a lot, they would be around 200$ or so. Good Product.
  • 3 weeks later...
    • No, not yet. Hoping I'll have something a little more definitive in the next day or 2. They seemed to be very confident they can order it. I do have some understanding of the whole allocations and restraints stuff so we'll see.   I think this is what I'm looking for.   3000 ORDER ACCEPTED BY PRODUCTION CONTROL
    • Then you haven't read your book. It also says check every 400 miles.   If you need to add multiple quarts in that distance then reading the stick isn't the issue. Put the two together and it will make sense. Read it all.
    • Following up on my topic, I put an O2 sensor in it which seems to have got rid of all the b2s1 codes (I ended up having multiple codes). Next I’ll try to figure out the P0011 but I might focus on exhaust manifolds first, they’re getting pretty rusty. I’m hoping this thread will help someone in the future.
    • I’m going off the instructions.
    • My expectations are a bit higher.    No faded paint or dry rotted plastic/rubber. I use a dressing and a ceramic sealant. No hazy headlights.  No door dings. Small dent in the front bumper. All rock chips repaired. No brush scratches. No windshield chips. No fender benders. Limit damage due to a proactive plan the included ceramics and PPF and prompt attention to any exterior issue. NO RUST. Stays out of the salt and had the rear wheel wells Line-X coated as well as the bed which has a bed rubber and has been under cover since before I bought it. Washed and detailed regularly. Rex chewed up the tow button, got whacked and the button replaced the same week. He's leaned his lesson. If I can train a dog the kids are easier.    All suspension is original save the King Shocks I installed very early on. 50 years ago dad told me a good shock will keep the screws in the dash tight and the front end mint. He was right. Everything within new spec yet, tight and aligned well several times. Coolant system is OEM save the modifications I made early on. Not a single leak anywhere on this machine. (Did repair an intake leak on #4 during the HPFP replacement.) The injectors I replaced didn't need to be. They checked out great. One of those, while I'm in there with the manifold off and the fuel rail apart things.  Not a stain or abrasion one to the upholstery. Have kept is covered since new. Never had a carpet, it's a work truck but the carpet squared I laid on the floor have keep the factory rubber liner MINT. Ceramic wind tint helps preserve the interior.    Original BRAKES with 60%+ left of the pads and rotors mic excellent. We just did a full preventative brake service. Disassembly, clean inspect including measurements, lube, Dot 4 power flush including ABS system.    OEM battery. OEM vacuum pump. In fact the only things not OEM are a pinion seal the high side pump and injectors and a small plastic shield around the starter. All hoses/belts etc.. are still in service and doing well. Original tires lasted 125K and had I known some additional details would have made it to 150K with legal tread. (Date out is six years, not 5 and Continental says they are good for 10 so I pulled the trigger to early)   I never let my children or grandchildren run the show. Feet on the floor and hands in your lap. Dog gets a pass.    A truck is a machine the gives you back whatever your willing to put into it. Same as a computer or a butter knife. I use a shovel but I scrap it, hose it off and oil it when I'm done with it. My original spade I've had 60 years.      Set the bar higher...you spend less money. No, before you ask, I have spent a fraction of the cost of a new truck in my entire maintenance program including disposables, filters/fluids etc.
