California Truck Jamboree is BACK! August 28th 05'
Truck Jam
Toyo Tires Summer California Truck Jamboree returns with the Hottest Show of the year on SUNDAY August 28th, 2005 - 9:00am to 5:00 pm - Hidden Valley Park at Verizon Amphitheater in Irvine CA. Focusing on an event that has everything to do with trucks! Air Hopping Contest, and over 600 of Hottest Custom & Classic Trucks coming from all over the US to compete for cash, prizes and over 175 trophies, Coverage by ESPN and many other Media sources, Exhibitors displaying and selling the best products, an Outrages Bikini contest girls compete for $1,500 in cash, prizes and feature layout to the winner in Tailgate magazine, pie eating contest, performances by ShotBlue, MAD House FX, Dunk tank, where proceeds go to the Alesecoco.org foundation,
Under new ownership, bringing back the good old TRUCK JAM..... The way it should be... Come enjoy the day ... SUNDAY August 28th, 2005 - 9:00 am to 5:00 pm - Hidden Valley Park at Verizon Amphitheater in Irvine CA.
California Truck Jamboree.............
Show Truck Entries are $30 pre-reg. and entered to win a set of Toyo Tires or $40 at the gate. Spectator tickets are $12.00 with discount coupons available online Visit the NEW www.TruckJam.com or Call 310-326-4JAM (4526) or Fax 310-539-0935. For more info...
Please make sure you all pre-register to ensure show vehicle entry!
Please let us know if you have any questions.
Thank you,
_________________________
Truck Jam Staff
California Truck Jamboree, Inc.
1966 Lomita Ave.
Lomita, CA 90717
“Leader since 1987”
www.truckjam.com
310-326-4526
SEE YOU AT THE SHOW!!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
