Tranny Pan Recommendation
Hi All,
I'm taking in my 2004 Silverado 1500 Crew Cab for tranny service. The factory pan DOES NOT have a drain plug.
Should I go for an aftermarket aluminum or a FACTORY pre-2003 with the drain plug?
Any recommendation on aluminum (besides $$ Mag-HiTech)?
Thanks in advance...
P.S. That is not a drain plug it is a place to test your patience ad sockets.
Boy,Thats the truth,The drain plugs are put on soooooo tight on the factory pans hardly anyone can get them off :chevy::jester:
Guest chevydeerhunter
Whatever you do, get a good quality pan by TCI, B&M or any other pan by a reputable company. The cheapest I've found so far in the aluminum extra capacity models are either at www.summitracing.com or www.jegs.com for $166.99 without shipping. They come with gaskets and mounting hardware and a drain plug.
I replaced my transmission fluid with AMSOIL last week on my 2004 K1500 CC. What a pain! I still do not know how to properly remove the pan because I don't know what to do with the bracket for the cable other than bend it out of the way. Anyway not having a drain plug really wasn't too much of a disadvantage as I loosened the screws a bit and let it partially drain. Then I siphoned (using a $5 siphon) the remaining bit out. Knowing now that there is really no interference next time I will just siphon through the dipstick tube.
OK,
Here are my choices from Summit Racing:
Summit Manufacturing Aluminum Transmission Pans
Transmission Pan, Deep, Aluminum, Natural, Finned, 700R4/ 4L60/ 4L60E, Each
Today $114.95
Brand: Summit
Product Line: Summit Manufacturing Aluminum Transmission Pans
Transmission Pan Material: Aluminum
Transmission Pan Finish: Natural
Transmission Pan Style: Deep
Capacity Increase: 2 qt.
Drain Plug Included: Yes
Filter Extension Included: Yes
Filter Included: No
Gaskets Included: No
Bolts/Studs Included: Yes
Temperature Sender Bung Included: No
Quantity: Sold individually.
Notes: Finned.
TCI Aluminum Transmission Pans
Transmission Pan, Deep, Aluminum, Natural, 700R4/ 4L60E, Each
Today $129.88
Brand: TCI Automotive
Product Line: TCI Aluminum Transmission Pans
Filter Extension Included: No
Filter Included: No
Gaskets Included: Yes
B&M Automatic Transmission Deep Pans
Transmission Pan, Deep, Aluminum, Natural, 4L60/ 4L60E, Each
Today $166.95
Brand: B&M
Product Line: B&M Automatic Transmission Deep Pans
Capacity Increase: 3 qt.
Filter Included: No
Hughes Performance Deep Aluminum Transmission Pans
Transmission Pan, Deep, Aluminum, Natural, Ribbed, 4L60E, Each
Today $139.95
Brand: Hughes Performance
Product Line: Hughes Performance Deep Aluminum Transmission Pans
Filter Included: No
Transmission Pan, Stock, Aluminum, Polished, 700R4/ 4L60E, Kit
Today $121.99
Transmission Pan Finish: Polished
Transmission Pan Style: Stock
Capacity Increase: None
Filter Included: No
Quantity: Sold as a kit.
Notes: Stock depth pan. Uses stock filter.
My only concern is with the filter extension coming loose on the EXTRA CAPACITY models. For this reason I am leaning toward the STANDARD CAPACITY TCI model.
Thanks again for all the help!
I had the TCI extra capacity aluminum pan on my 1998 K1500 with a 4L60E and loved it. It came with everything needed to change over to the new pan. The drain plug worked wonderfully. There is no filter extension needed with this pan. It uses the stock filter. There are posts cast into the bottom of the interior of the pan that support the stock filter. Some people might say that the filter does not get that fluid because it is not on the bottom of the pan but the returning fluid circulates that fluid below the filter. The extra capacity is worth it for lower transmission fluid temperatures.
